Electronics => Electronics => Topic started by: galannthegreat on May 14, 2010, 09:51:19 AM
I'm getting a little confused with an LCD I'm currently working with. The datasheet shows timing diagrams of 68-type and 80-type microcontrollers... I get that, but the question is; Are AVR's based off of 68-type or 80-type micrcontrollers?
Here is the datsheet: http://www.newhavendisplay.com/specs/NHD-12232WG-EYYH-VA.pdf (http://www.newhavendisplay.com/specs/NHD-12232WG-EYYH-VA.pdf)
I would say neither 68-type (motorola 68k) nor 80-type (intel 8086? not sure about this one).
Take the simplest one and see what happens. If it doesn't work, try adding delay to respect the timing diagram.
You can also look at the controller datasheet:
http://www.newhavendisplay.com/app_notes/SBN1661G.pdf (http://www.newhavendisplay.com/app_notes/SBN1661G.pdf)
Yea I've been looking at the controller datasheet for some days now, and I'll prolly end up trying out both timing diagrams. But it just seems so confusing, I wish they just had a generic timing diagram.
That would apply of you are attaching the controller to the data bus, which is internal to the microcontroller (there are minor exceptions). Since you are dealing with a microcontroller and controlling the LCD through ports, then YOU have control over that port and the timing involved with those pins. The 80/68 distinction doesn't apply.
Hi
Iam also using the same LCD with host controller from MSP430 series from TI. I dint find any sample code for this LCD from NHD so i took sample code of the other LCD modified and used for this LCD. The problem is what ever the control signals and the data sent is seen on the LCD pins when i debugg but the data is not displayed.
I have sent al the commands recommended by NHD.By using contrast Iam now able to see all the pixels dark. Iam neither able to see the data sent nor the there is no change in the pixels colour when i send all zeroes.
Please can u suggest where could be the problem for data not being displayed on the screen. From the timing diagram i understood that the min delay to be given is in nanosecs. But i gave more delay, could this be a problem. Iam totally clueless. Iam not able to find the problem to think of the solution. Please help me in this.
thanks,
narahari.
I am still trying to figure out, on my spare time, how to get commands working for this LCD. To be brutally honest, at this point I'd recommend, if possible, that you move on to a more well documented display as NHD has not given me any help with this display.
http://www.sparkfun.com/products/710 (http://www.sparkfun.com/products/710) is a good example of an LCD that I find easy to work with. There is also a serial enabled version, http://www.sparkfun.com/products/9351 (http://www.sparkfun.com/products/9351).
Hope this helps, I will still be tinkering with that display, but with the time it has been taking figuring it out it isn't on my priority list.
Dear Kurt,
Thank you for the reply. I have very basic question. When i switch on LCD and adjust the contrast Ican see all the pixels dark. but all of them disappear when i remove clock pin from the LCD. ithink tis is the right behaviour.
2. When i send a byte of data how will the character appear? the particular charcter will be displayed and rest all characters also will be highlighted?
3.When i send zero continously for 122 times then will all the pixels disappear?
Because Iam stuck up< Iam not able to see if the character is ent or not.
