Electronics => Electronics => Topic started by: junior000 on January 28, 2008, 03:05:41 AM
Title: battery specifications
Post by: junior000 on January 28, 2008, 03:05:41 AM
hi,
  need some clarification.
  if a battery storage capacity is 9v 2100mah,what does 2100mahh stand for???
Title: Re: battery specifications
Post by: SmAsH on January 28, 2008, 03:10:18 AM
is the second one supposed to have 2 h's?
Post by: robonoob on January 28, 2008, 08:01:55 AM
NO!
and that means that thiss battery can give 2100mA for an hour. if u use less amps then it will last longer. say you need 1050 amps, then the battery will last for 2 hours  etc :)
Post by: airman00 on January 28, 2008, 07:35:19 PM
NO!
1050 ma not amps! that is some high current stuff
mah stands for milliamps hour , as robonoob said it can give 2100 milliamps continuously for a hour
Post by: robonoob on January 29, 2008, 11:27:11 AM
oops :D yea thats what i ment. mAmps not Amps :)
Post by: HDL_CinC_Dragon on January 29, 2008, 12:44:14 PM
Thats nothin'. I once bit into a 4 trillion amp wire just to see what would happen.... (holy crap imagine the wire thickness needed to contain that much amperage... it would have to have the same diameter as friggen Jupiter lol)
"mAh" = "Milliamp hours"
To find out how long said battery will last, there is a simple equation:
[battery-mAh-rating] / [circuit-mA-requirement] = [battery-life-in-hours]
Post by: karmax on February 06, 2008, 01:28:17 AM
 :) It simply means that if u takes 2100ma current from urs battery then it can run for 1 hour
