Electronics > Electronics
9V to 6v ac adapter
<< < (3/3)
waltr:
--- Quote ---If you are talking about an AC adapter that outputs AC voltage, then you have to use a transformer; a regulator will not work.
--- End quote ---
This is not completely true.
It would be easier (and is more common) to rectify the 9VAV to DC, Filter with a large cap, then regulate to 6VDC with either of the linear regulator I listed in post #2.
jwatte:
--- Quote ---It would be easier (and is more common) to rectify the 9VAV to DC, Filter with a large cap, then regulate to 6VDC with either of the linear regulator I listed in post #2.
--- End quote ---
You are trying to accomplish something else with that statement. You are trying to *both* do AC-DC conversion, and voltage regulation.
If you have 9V AC out, and want 6V AC out, then a linear regulator will not work. At all. If you read the original question literally, that's actually what's being asked.
vipulan12:
no i want 6v DC out
jkerns:
--- Quote from: vipulan12 on July 18, 2013, 11:52:23 AM ---no i want 6v DC out
--- End quote ---
So, if you have a 9 volt DC supply, all you need is a regulator (a capacitor on the input and output are often a good idea also).  If you have a 9 volt AC supply, you need a rectifier (typically a bridge rectifier), some filtering and a regulator.
Navigation
[*] Previous page
