Electronics => Electronics => Topic started by: zack on June 09, 2008, 07:47:12 PM
Hello!
does anyone know the jameco part number of the 1 pin female socket found on jumper wires?
(http://www.robotcraft.ca/webshop/images/Large-JumperWire-Female-02-L.jpg)
Ha. youre lucky I saw those on sparkfun and hunted around for them. trust me, it took some digging.
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=516200 (http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=516200)
product no. 516200
It has a locking ramp, there is a 1 pos molex connector out there with no ramp but it didnt pop up when I searched jameco.
I saved this PDF to save me some heartache in the future.
http://www.molex.com/catalog/pdf/MX2695.pdf (http://www.molex.com/catalog/pdf/MX2695.pdf)
Bukowski, you are a life saver! ;D You must be pretty good at wading through catalogs! I spent quite an amount of time, but couldn't find this part. Thank you!
It is quite sad that there isn't one standard way to connect cables. The only standard way I guess is soldering! People who migrate from the lego nxt world to the world of robotics/electornics are in for a rude shock! :D
Hello,
I ordered this and found out that that wasn't the one. What I received was much larger that what's pictured in this thread. Anyone know the Jameco part number?
Found 'em at Digikey.
Right Here (http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=609-2342-ND)
Wow, really? According to the Molex datasheet / dim dwgs, part no. 0022012011 (the one w/ no locking ramp) is .190" tall and .122" wide... which seems about right... Sorry :-\
Thanks Krich! Don't beat yourself bukowski. I know how hard it is to tell from just looking at a catalog if that is indeed the part we want. And with so many types of connectors it is easy to make a mistake.
For one pin molex, I just crimp on the metal part to the wire, then heat shrink it.
