Electronics => Electronics => Topic started by: Blood-man on August 09, 2009, 09:50:06 AM
I'm really confused by the photoresistor tutorial. I used analog multimeter and biggest photoresistors from Radioshack set. I get 6.703 KOhm. Is it OK? And can you explain me why I need to solder the end of photoresistor to the ground? I thought that it got to be analog output, because microcontroller not gonna read the ground, so it don't make any sense.
a photoresistor is a variable resistor. It changes its value with different amounts of light. You are simply creating a voltage divider circuit where you ADC channel connects between the two resistors.
gnd-------Photoresistor--- to ADC ----normal resitor---+5V
or
+5V-------Photoresistor--- to ADC ----normal resitor---gnd
the only difference is whether the voltage will increase or decrease which more light
