Mechanics and Construction => Mechanics and Construction => Topic started by: airman00 on September 28, 2008, 05:45:41 PM
Title: Build a Vision Line Following Robot Chassis
Post by: airman00 on September 28, 2008, 05:45:41 PM
Hello Everybody ,
I am now working on my line following robot that uses a CMUcam as its main sensor. I am looking to build my own chassis and was wondering which motor gearboxes you'd suggest .  I'd like the gearboxes to last a long time and also I would like to operate them at 6V.
There isn't any significant weight on the robot ,but one thing that requires more torque is that the robot must be able to go up a 25 degree ramp.
The total weight of the payload (not including gearboxes) is around 8 ounces.
Also I do not want to use servos because they are too slow.
My choice right now is this one: http://www.trossenrobotics.com/store/p/4918-GM9-Gear-Motor-143-1-90-degree-3-6V.aspx
Can anyone help me find a better gearbox then the one mentioned?
Title: Re: Build a Vision Line Following Robot Chassis
Post by: airman00 on September 28, 2008, 05:56:12 PM
OK so I calculated RMF for the robot when it is on the 25 degree ramp:
RMF - 0.595 lb*ft*rps
Momentum - 0.400  lb*ft*s
Motor Rotation Speed- 0.637 rps
When it is off the ramp it only needs an RMF value of 0.0212 lb*ft*rps, meaning it will go extremely fast when there isn't any incline ( which is good , :) )
Post by: pomprocker on September 28, 2008, 07:33:47 PM
You sure don't know how to stick to one project through completion  :P
Post by: airman00 on September 28, 2008, 08:00:50 PM
lol , I like to do many projects at once . That way if I get frustrated with one project ,I take a break from it and go on to the other one.  I'll make a post about my projects actually.
Post by: Admin on September 30, 2008, 04:19:33 AM
I think you mean DC motors with an attached gearbox :P
As for those GM9 Gear Motors, I hear they have a short lifetime . . . but can't remember where I read that :-\
