Electronics > Electronics
Transistor overheating...
MasterRyko:
We are getting way too much heat from our transistor in our motor driver circuit. We can't use a lower resistor because of current restrictions. Are there any alternatives? We need 1 amp to run our motor and we're using a TIP31 NPN transistor with a 340 ohm resistor and a 5 volt source.
Tsukubadaisei:
The heating is normal and inevitable. You must attach some metal(aluminium) plate to the back of your transistors(use those holes that big transistors usually have, they are supposed to be holes for screws) and/or install a mini brushless fan. I like fans, personally.
KambeiX:
how much is the base current? it should be in the mA range but you could check anyways.
Also as Tsukubadaisei said, attach a heatsink and if heat is still too high (getting too close to 150°C for TIP31) then you must use a fan.
Admin:
For motor control you should use a MOSFET with a big 'ol heatsink on it, not a transistor.
Brandon121233:
Well I would go with a H-Bridge, if its for motors, lots more features and simpler to work with than building your own H circuit out of MOSFETS
Navigation
[#] Next page
