Software => Software => Topic started by: tmoney68 on July 12, 2010, 11:20:03 PM
Since I am strictly a linux user, I have decided to play around with Eclipse. I have downloaded the current version and installed the AVR plugin. It seems to work very nicely. My question is how to include webbotlib? Has anyone done this? Its probably an easy solution, but I can't seem to figure it out.
Thanks in advance
Have you read Dunks tutorial at http://www.societyofrobots.com/member_tutorials/node/381 (http://www.societyofrobots.com/member_tutorials/node/381)
Does that help?
Does that help?
that doc does not cover Eclipse.
but it is good background reading.
so presuming you know how to include WebbotLib from the command line it's pretty easy.
in Eclipse, open your project then go
Project -> Properties -> C/C++ Build -> Settings .
then under Tool Settings point to the various WebbotLib directories and the libWebbot-ATMegaXXXX.a file under the relevant sub sections as you would from the command line.
Thanks, I knew it would be something simple!
Hi Dunk! Hi tmoney!
I'm new to all of this (including use Ubuntu for programming AVR's), and I don't know how to include WebbotLib from the command line / Eclipse.. ???
I only achieved to use AVR plugin with Eclipse :-X
Please, can you make a Step-by-step tuto?
Thanks in advance!
