main gear-modify servo is this what we should cut out
rox2007:
attached is the picture of underneath the main gear. i just want to know if the part circled red is what we should take out
ed1380:
you cant really take it out. i think.
if you cant then cut off the part of the pot that's supposed to go in that hole
rox2007:
if i have a drill cant i drill it out. make it rounder so that the large gear can rotate freely.
ed1380:
yes but it'll weaken the gear. it's already plastic and weak
bukowski:
you should be able to pop it out with some needle nose.
I had trouble with metal geared servo's with a ball bearing, it did not want to come out, and you can just cut the pot head off, like ed said
Navigation
[#] Next page
