Software => Software => Topic started by: zwarte on November 07, 2012, 11:16:13 AM
As the title said, i have build-ed the $50 robot, and i would like to add 3 more photo sensors, for some reason 4 sensors wont work and it's not the connection. using led as indicator of input/controle change.
My edited code:
LED_on();//turn LED on
while(1)
//store sensor data
sensor_front_left=a2dConvert8bit(5);
sensor_front_right=a2dConvert8bit(4);
sensor_right=a2dConvert8bit(3);
sensor_left=a2dConvert8bit(2);
sensor_ass=a2dConvert8bit(1);
//detects light infront of robot
if(sensor_front_left = sensor_front_right && (sensor_front_left = sensor_front_right) > threshold)
{ //If front sensors are equal on light, go straight
LED_off();
servo_left(25);
servo_right(44);
LED_on();
//detects more light on left side of robot
else if(sensor_left > sensor_front_left && (sensor_left - sensor_front_left) > threshold)
{//go left
LED_off();
servo_left(44);
servo_right(44);
LED_on();
//detects more light on right side of robot
else if(sensor_right > sensor_front_right && (sensor_right - sensor_front_right) > threshold)
{//go right
LED_off();
servo_left(25);
servo_right(25);
LED_on();
//detects light behind robot
else if(sensor_ass > sensor_front_left && sensor_ass > sensor_front_right && sensor_ass > sensor_right && sensor_ass > sensor_left > threshold)
{//go back
LED_off();
servo_left(44);
servo_right(25);
LED_on();
The back (ass) sensor is tenth for driving back if it accidently drove in a dark space.
ANy programming ideas?
What do you mean by "won't work"? You are not getting the readings into the MCU? The motors are not changing speeds? It's not following the line well? Or...???
i managed to get it working with 5 sensors.
int main(void)
//declare variables here
//int i=250;//a 'whatever' variable
int sensor_front_left=0;//left photoresistor
int sensor_front_right=0;//right photoresistor
int sensor_right=0;//left photoresistor
int sensor_left=0;//right photoresistor
int sensor_behind=0;//right photoresistor
int threshold=6;//the larger this number, the more likely your robot will drive straight
/****************INITIALIZATIONS*******************/
//other stuff Im experimenting with for SoR
//uartInit(); // initialize the UART (serial port)
//uartSetBaudRate(9600);// set the baud rate of the UART for our debug/reporting output
//rprintfInit(uartSendByte);// initialize rprintf system
//timerInit(); // initialize the timer system
configure_ports(); // configure which ports are analog, digital, etc.
a2dInit(); // initialize analog to digital converter (ADC)
a2dSetPrescaler(ADC_PRESCALE_DIV32); // configure ADC scaling
a2dSetReference(ADC_REFERENCE_AVCC); // configure ADC reference voltage
//rprintf("Initialization Complete\r\n");
LED_off();//turn LED on
while(1)
//store sensor data
sensor_behind=a2dConvert8bit(1);
if(sensor_front_left > sensor_front_right && (sensor_front_left - sensor_front_right) > threshold)
{//go left
servo_left(44);
servo_right(44);
else if(sensor_front_right > sensor_front_left && (sensor_front_right - sensor_front_left) > threshold)
{//go right
servo_left(25);
servo_right(25);
else if(sensor_left > sensor_right && (sensor_left - sensor_right) > threshold)
{//go left
servo_left(44);
servo_right(44);
else if(sensor_right > sensor_left && (sensor_right - sensor_left) > threshold)
{//go right
servo_left(25);
servo_right(25);
else if(sensor_behind > sensor_front_left + sensor_front_right && (sensor_behind - sensor_front_right - sensor_front_left) > threshold)
servo_left(44);
servo_right(25);
//light is about equal on both sides
else
{//go straight
servo_left(25);
servo_right(44);
