Mechanics and Construction => Mechanics and Construction => Topic started by: Sylvestre on December 18, 2011, 01:05:41 PM
Hello,
How would I put two sprockets on a motor's driveshaft like the one in the link below? Would I need to extend the axle using some type of adjoiner? http://www.monsterscooterparts.com/24vo400wamow.html (http://www.monsterscooterparts.com/24vo400wamow.html)
The reason I want to do this is so I my robot will be fourwheeled drive. Similar to a skid steers drive system http://tinyurl.com/csjjrla (http://tinyurl.com/csjjrla)
Before, I thought about doing something similar to the picture below, but then I realized the method above would be better.
What are your guys' thoughts?
Could anyone verify my proposed method or does anyone have another suggestion of how I could do this?
I don't see a problem with your drawing. The only suggestion I could think of is adding a tensioner sprocket/pulley to your existing design. It would allow more teeth of your top sprocket to stay in contact with the chain (less chance for slippage), and also allow for a possible suspension system for your axles. Not to mention a tensioner also allows for easy removal/service to the system.
Ok thanks for the reply! I'll do just that.
