Software => Software => Topic started by: michaelghayes on January 31, 2009, 01:07:48 AM
i was wondering if someone could take the time to show me the code for using the sensor data from a sharo ir range finder. I have everything hooked up on my robot and i can control the servos and make it moved in a preprogramed way, but i haven't figured out how to make the sensor do anything. (im using an axon controller if that helps)
there are 2 things id like to be able to do, and if i see the code for them i think i can figure everything else out
1)
I want to have the axon send the range that the ir sensor is perceiving through hyperterminal about once per second (not to fast) in inches or centimeters if possible.
2) I want to know how to get the range in cm or inches as a function so i can have somthing like
void control(void)
long unsigned int wheel_left=500;
long unsigned int wheel_right=500;
while(1)
if(sensor() > 20){
strait(100);
else
reverse(100);
void strait(int s)
for (count = 1; count <= s; count++){
wheel_left(1200);
wheel_right(200);
delay_ms(15);
void reverse(int rv)
for (count = 1; count <= rv; count++){
wheel_left(400);
wheel_right(1000);
delay_ms(15);
unsigned int sensor(void)
?????? what would i put in here to have this return the value of the sensor (on the header pin 0 (axon controller top row, im not sure what its called header I think)??????
etc...
could this work and if so, how would i do the sensor data thing, i have no idea how to read the sensors, and i don't know if i need to define them in hardware.c or in the sensors.c, please any help would be very helpful thanks
You will find all code here:
http://www.societyofrobots.com/axon/axon_function_list.shtml
The default photovore code has lots of examples with lots of comments.
here are a few examples for you:
//create a variable
int sharp_IR;
//read raw data from sharp IR on pin 0
sharp_IR=a2dConvert8bit(0);
//or read Sharp IR data and convert to cm on pin 0
//if you were using the GP2D12 sensor, put that at the end, etc
sharp_IR=sharp_IR_interpret_GP2D12(0);
sharp_IR=sharp_IR_interpret_GP2Y0A02YK(0);
sharp_IR=sharp_IR_interpret_GP2D15(0);
//print the data to Hyperterminal
rprintf("value = %d\r\n",sharp_IR);
thanks, that was really helpful and alot easier than i thought, i should be able to figure stuff out now :)
