Electronics => Electronics => Topic started by: gamefreak on April 25, 2010, 07:28:09 PM
For my current project I need to run a brushless motor at full speed and have no idea how to do this.
A little research shows that the motor controllers take PWM to control the motor and from my understanding of that simply holding the input high should by 100% but that does not work, any ideas?
Do PWM signals with a duty cycle less than 100% work? If not, I'd think it's something wrong with the controller, or with your signal.
If I hook it up to a standard radio receiver I can run it just fine. I notice that it makes a beep when I hook it up to the RC receiver and then turn on the transmitter so I am guessing there is something else going on.
It is not PWM in the sense of 100% is on and 0% is off:
(http://bansky.net/blog_stuff/images/servo_pulse_width.png)
Sounds like you have an ESC on it. Which is it (make and model)?
Electronic speed controller? I'm just making sure.
Yes.
as Razor says,
RC pulses are not simple PWM signals. you still need to generate a pulse every 20ms or so.
use a pair of ne555 to generate a 2ms pulse every 20ms.
It is a Power Up 20A ESC with a 2A BEC, meant for Lipo 2-3 cells or NiMh 5-10 cells, there is no more info written on it.
I guessed I would have to use a 555 timer but I was hoping for an easier solution, in any case i'll hunt through my stuff for a couple 555 timers and see if I can get it to work.
A single 555 should do.
Alright now the other question I had is: Does the Battery Elimination Circuit(BEC) regulate power and can I use it to power the 555 and control the motor?
I am guessing that it would since too much power would blow those expensive RC rigs and a quick google search confirms but RC is not my friend and I can not test anything until at least 8 hours from now(curse you school, always preventing me from learning....).
The schematic floating around my head is basically the batteries hooked up to the ESC with the wire meant for the RC receiver heading towards a PCB with a 555 timer on it designed to output (as close as possible)a full on PWM signal.
Unfortunately I also have the vision of this thing suddenly jumping to life and tearing itself apart from the sudden jump in speed. Is there any way to make it start slow and after a few second reach top speed and sit there?
BEC output provides a regulated 5v at 1 to 2 amps
if you want simpler than that have you considered ditching the brushless motor and using a DC motor instead?
Well a plain old DC motor is electrically friendly, I never quite got the concept of couplers down. Couple that(hehe, its a pun) with low torque and 20k+ RPM +/- 12% I am not a fan. The BLDC motor has a threaded shaft and gets about 1000 RPM/V, it also has more torque and is more mechanically friendly then the ordinary motors. It is just a matter of getting the electronics to work...
This circuit works great, I've tried it:
(http://www.sentex.ca/~mec1995/gadgets/servo4.gif)
(http://razorconcepts.net/img/openrc/driver2.jpg)
Yes to both counts.
Does the manual say anything on the length of a full signal (it varies a bit depending on manufacture).
The easy way to do that would be to make the signal in a small controller, that way you can program any curve you want.
In a 555 it would need some extra work and just toying with the control voltage input would change both the pulse and the pause, so won't do, while in controller it's a piece of cake.
