Software => Software => Topic started by: thornsb1 on October 24, 2010, 06:36:42 PM
Here is the source code that Webbot generates for a project with one servo. In order to learn how to control servos I am only using one servo at this time. The problem is that this code moves the servo backwards and forwards continuously. I want to be able to command any number of servos to move to a certain position and stay in that position while other servos do something. I know how to change the center and range but I can't get the servo out of the loop. Can someone tell me what I would have to change to make a servo stop at a certain position without moving again until later? Also, if there is a good strategy for this kind of programming I would appreciate any suggestions. Thanks Guys!
#include "hardware.h"
// Initialise the hardware
void appInitHardware(void) {
initHardware();
// Initialise the software
return 0;
// This is the main loop
TICK_COUNT appControl(LOOP_COUNT loopCount, TICK_COUNT loopStart) {
// -------- Start Switch/Button-------
// Switch/Button - see switch.h
// To test if it is pressed then
if(SWITCH_pressed(&button)){
// pressed
// To test if it is released then
if(SWITCH_released(&button)){
// released
// -------- End Switch/Button-------
// -------- Start Marquee-------
// Marquee - see 'segled.h'
// Before using the Marquee you need to redirect rprintf to write to it
// This can be done using
Writer old = rprintfInit(marqueeGetWriter(&marquee));
// All rprintf output will then be sent to the marquee but will not
// display until an end-of-line eg "\n" has been sent. Example:-
// rprintf("Hello World\n");
// If the endDelay is non-zero then the marquee will scroll
// forever or until you call: marqueeStop(&marquee);
// If the endDelay is zero then the marquee will stop once
// the entire line has been shown ('one-shot' mode)
// In 'one-shot' mode then you may want to make sure that
// a previous line has finished before you display a second line.
// This can be done as follows:-
marqueeSetEndDelay(&marquee,0); // Make sure we are in one-shot mode
if(marqueeIsActive(&marquee)==FALSE){
if(loopCount==1){
rprintf("ABCDEFGHIJKLMNOPQRSTUVWXYZ\n");
}else{
rprintf("Loop=%u\n",(unsigned)loopCount); // Put the loop count
// Restore rprintf back to its previous location
rprintfInit(old);
// -------- End Marquee-------
// -------- Start Actuators -------
// To control your.motors/servos then see actuators.h in the manual // To retrieve the required speed of servo1 use:
// DRIVE_SPEED speed=act_getSpeed(servo1);
// To set the required speed of servo1 use:
// act_setSpeed(servo1,speed);
// This example will move the motors back and forth using the loopStart time:
TICK_COUNT ms = loopStart / 1000; // Get current time in ms
int16_t now = ms % (TICK_COUNT)10000; // 10 sec for a full swing
if(now >= (int16_t)5000){ // Goes from 0ms...5000ms
now = (int16_t)10000 - now; // then 5000ms...0ms
// Map it into DRIVE_SPEED range
DRIVE_SPEED speed = interpolate(now, 0, 5000, DRIVE_SPEED_MIN, DRIVE_SPEED_MAX);
// Set speed for all motors/servos
act_setSpeed(&servo1,speed);
// -------- End Actuators -------
return 0;
