Electronics => Electronics => Topic started by: izaktj on October 25, 2008, 10:40:33 PM
Title: Assorted $50 robot questions [UNANSWERED QUESTIONS ON 1ST POST]
Post by: izaktj on October 25, 2008, 10:40:33 PM
Unanswered questions:
None ATM  ;)
Answered questions:
1- 28 Pin DIP socket, what is it's function? (Yes I searched before asking)
2- Is it the same if I connect the servos ground to the 9v battery ground or 5v(regulated) ground? (I'm using battery pack)
Thanks.
Title: Re: What is the $50 28 PIN DIP SOCKET for?
Post by: airman00 on October 25, 2008, 10:56:51 PM
so when u kill your ATmega chip , you can pop it out and replace it with a new one
Post by: izaktj on October 25, 2008, 10:57:57 PM
That's it?
So if I'm using a breadboard I don't need it right??
Post by: airman00 on October 25, 2008, 11:27:05 PM
right
Post by: izaktj on October 26, 2008, 12:09:59 AM
right
Great! Thanks a lot mate!
Title: Re: Assorted $50 robot questions [UNANSWERED QUESTIONS ON 1ST POST]
Post by: izaktj on October 26, 2008, 03:58:17 AM
Post by: dunk on October 26, 2008, 04:27:23 AM
all grounds should be connected together everywhere.
if you are using more than one battery pack in a circuit you will need to connect all grounds together.
your servo ground should definitely be connected to the GND on your 9v battery AND your 5v(regulated) GND.
i don't know the details of your circuit but 9V will be too much for your servos.
you will need to power then from a 5-6V source. (again make sure all the GNDs are tied together.)
Post by: izaktj on October 26, 2008, 05:05:56 AM
Woot thanks mate!  ;D
I'm using a 6V for the servos and 9V regulated to 5V for the micro and digital inputs.
Post by: yankeefan238 on October 26, 2008, 02:39:36 PM
If you are going to use a 9v battery and regulate it to 5v you are gonna waste lot of energy and your regulator is going to emit a lot of heat.
Post by: izaktj on October 26, 2008, 03:10:46 PM
I'm following the $50 robot tutorial  ???
Post by: yankeefan238 on October 26, 2008, 04:01:10 PM
you can use the 9V but I'm just saying that using 6V is more efficient.  ;)
Post by: izaktj on October 26, 2008, 05:51:16 PM
Oh I see, yeah I understand. Thanks mate.
