Electronics => Electronics => Topic started by: airman00 on October 19, 2008, 12:47:23 PM
If you look in my PCB I designed you'll see a little solder hole thing right above the FTDI chip .
What is that solder hole thing and what am I supposed to do when I get my PCB in the mail? Solder in that hole? Leave it be?
(http://i273.photobucket.com/albums/jj202/erobot/Misc%20Documentation/Transmitter1.jpg)
Problaby a plated through hole. A way to carry a lead from one side of the board to the other side. So two leads dont cross.
I thought it was something like that
but do I have to fill in (solder it) the hole? or is it good the way it is?
It is plated through by the PCB manufacturer, no need to solder it.
Ok thank you
Its called a via.
Vias are bad for high power tracing, and for noise sensitive circuits. For your circuit it's no big deal.
You should go all surface mount for this board - I'm willing to bet it will allow you to halve the size.
