go away spammer
 Search results for: axon bootloader 64
1
Software / Windows 7 64bit Bootloader for Axon II
« by Popcorn97 on March 02, 2010, 03:38:54 AM »
......  everyone, i just got a Axon II yesterday and found out the bootloader doesnt  ............  on 64 bit windows 7 OS. im new to robotics (well i've  ......
2
Software / 64bit / 32 bit Axon II bootloader (flasher) NOW AVAILABLE
« by kl22 on April 14, 2011, 01:56:04 AM »
...... :  The programmer for the Axon has now been released. It is in beta so please  ............  version. And it has been tested on Windows 7 x64. But it also works for the x86 (32bit) versions.   ............  got around to finishing the development for a 64bit flasher for the Axon (not Axon exclusive, but  ............  that uses the same bootloader).  It's been done in Java, so cross-platform  ............  and Mac. Currently works in x86 (32bit) and x64 (64bit) Windows OS (tested on Windows 7 and Vista) ............  I can provide some interface so that other MCUs/bootloaders can be added to it without affecting the overall  ......
3
Software / I can not install the bootloader in Vista 64.
« by zuazons on May 13, 2009, 09:54:27 PM »
......  bought Axon MCU, but I can not install the bootloader in  ............  64 (Fboot v1.7.exe).  Could someone help me?  Thanks, ......
4
Software / Axon mote not recognised by hardware programmer
« by nm1 on December 21, 2011, 05:07:05 AM »
......  there,  I bought the two axon mote bundle but I think I may have bricked or  ............ - bricked one of them. The axon still works, it prints to serial and transmits  ............  my other mote still works fine I just flashed the bootloader and started using MCUber with it as I have a 64  ......
5
Software / Re: Axon 2 - Bootloader - program too large?
« by fxgovers on January 10, 2016, 01:07:32 PM »
...... , I found a solution. I went into the bootloader source code - the size of the code to be  ............  into the Axon 2 was arbitrarly set at 10,000. I reset it to 64......
6
Software / Axon and Vista: Help!
« by Joe on January 12, 2009, 06:40:55 PM »
......  my computer running Vista set up to program my Axon. After struggling to get the usb bridge driver to  ............  Hilgraeve Hyperterminal, but when I click on the Axon.ht icon it opens up but it says "cannot connect  ............  test it I try to see if I can program it with the bootloader. This, of course will not install because my  ............  system is 64 bit.  So after 3 days of trying I have gotten  ............  pull my hair out. How on Earth do you program an Axon with Windows Vista??? ......
7
Software / Trying to use Bootloader from Virtual Machine
« by madsci1016 on January 07, 2010, 04:58:46 PM »
......  have Win 7 64 bit running on my computers now, which makes  ............  the FBOOT bootloader useless, as it is not compatible with the  ............  win xp.   That trick seems not to work, as the bootloader seems to run ten times slower (the spinning /'s  ............  it takes 10 seconds for it to register that the Axon has been turned on) and it then says wrong device  ......
8
Software / Re: Webbotlib Studio FBoot only works the first time!
« by Webbot on October 08, 2014, 06:49:42 PM »
......  2014, 01:57:33 PM  I'm assuming when you used the bootloader and program that I sent you, you attempted the  ............  of the Axon II all from a Windows 7 64 bit computer? Is that  ............ ?    Yep - Windows 7 (Home Premium) 64  ......
