Electronics > Electronics
Potentiometer
(1/1)
YAN-1:
Hello everyone. I am in a huge need of a sliding linear potentiometer that is 9-10 cm long (travels 10 cm from one end to the other to cover the whole range), and that has a total resistance of 1 kilo-ohms or 2 kilo-ohms. Can anyone direct me to where I can obtain/purchase such a sliding potentiometer? Thanks a lot.
bulkhead:
I'm not sure where such a large one can be found, but as for the total resistance, it can be compensated for by adding a resistor in series (if the desired resistance is higher) or in parallel (if the desired resistance is smaller).
Admin:
The forum knows everything ;D
http://www.societyofrobots.com/robotforum/index.php?topic=429.0
http://www.societyofrobots.com/robotforum/index.php?topic=1394.0
HDL_CinC_Dragon:
dont suppose you could use a radial potentiometer and just put a pinion gear on it and have a rack be on this moving object of yours so that as the rack moves it turns the pinion gear thus turning the potentiometer?
just a suggestion...
Navigation
