Electronics => Electronics => Topic started by: Klinger on June 12, 2009, 09:28:07 AM
I have a Axon mircoController and BlueSMiRF attached together with Uart0. I trying to talk with it with my vista computer. I can see the module and I attach to it but I cannot talk to it. I am using Hyper terminal private edition. I talking to the same com port number 5. But if I try and do anything it say "com5 unable to open please check setting". Then vista normal ask for a pin number to talk to the robot. I checked on the same baud rate.
Here is my coding just in case
uartSetBaudRate(0, 38400);
char cByte= uart0GetByte();
while(1)
if(cByte =='1')
backward();
thanks
I found the Password 1234now the green 'connected' Light is on
the Com5 error is not there. But I still cannot type anything in.
Are you sure the bluetooth port is also com5? On my computer I never get the same port for different connections. go to device manager and clarify com5 is correct. Also make sure that you are selecting none for flow control.
no I am still on com 5 which is the 'SPP' profile
The Light is now Green, But I still cannot communcation with the Robot.
Nothing come up on the terminal screen
Strange that you are on com5, and it won't let me use any com less than 6 . . .
Try transmitting data instead. Do an rprintf("hello world"); and see what happens.
Also, your code should be this:
while(1)
if(cByte =='1')
backward();
I have fix the program so.
I put in the rprintf so but i just getting ASCII symbol on my screen and it is not listen to any commands that I type.
while(1)
cByte=uart0GetByte();
rprintf("Hello World \n");
if(cByte =='1')
while(1)
backward();
Your baud is wrong ;D
I have tried all of them it just say the same thing in ASCII
Show us more code . . . like what is cbyte initiated as?
