Universal Servomotor Bracket Assembly
Somchaya:
Ohh.. sorry, I haven't played with those before..
nanob0t:
You're the only one that has been avid looking for the diagrams, and judging by the extent of help, you're not going to get much better.
If you're constructing something, the best bet is to build your own. If something requires that product and nothing else, then you're stuck buying it. If not, make something to fit your needs. Even if you contruct your own, it's not going to be as precise as that bracket, so think of your options, or else do a lot more googling. If there's nothing on that website, then there probably will be nothing elsewhere.
Good luck.
ed1380:
sorry, but other than asking the store who the manufacturer is, or what the dimensions are, or buying one and making more yourself, there is no other choice
Admin:
get a sheet of metal that is 1 inch by 1 inch.
drill 4 holes in it, one in each corner:
two spaced exactly like the holes in the servo you already have (just measure it).
the other two any way you like to mount on your robot.
bend the sheet of metal in half.
wallah, a mount! :P
alephan:
well i see that i don't have another choice.... :( Thanks a lot guys!
Navigation
[*] Previous page
