Software => Software => Topic started by: Razor Concepts on May 25, 2009, 05:14:52 PM
I am shifting out 288 bits into a TLC5947 pwm driver. There are 12 bits of resolution (24 outputs x 12 bits = 288). 12 bits so 4096 possibilities. I am using Arduino for the sake of fast prototyping... but the code itself seems to be very slow. To test it out I am shifting out 288 bits 4096 times, code shown below:
int latchPin = 7;
int clockPin = 5;
int dataPin = 6;
void setup() {
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
void loop()
long a;
for(a = 0; a < 4096; a++)
digitalWrite(latchPin,LOW);
shiftOut(a);
digitalWrite(latchPin,HIGH);
// the heart of the program
void shiftOut(long myDataOut)
int pinState;
digitalWrite(dataPin, 0);
digitalWrite(clockPin, 0);
int outPut;
for (outPut=0; outPut < 24; outPut++) //24 different outputs
for(int val = 11; val >= 0; val--) //12 bit number
if ( myDataOut & (1<<val) )
pinState = 1;
else
pinState= 0;
digitalWrite(dataPin, pinState);
digitalWrite(clockPin, 1);
//stop shifting
However, going through the entire for loop takes roughly 25 seconds! Is there something particular that is causing this slowness or is simply turning all those pins high and low that many times slowing everything down. Since this is a fairly simple code I am thinking of switching over to true-c with AVR studio 4, with faster pin switching.
int latchPin = 7;
int clockPin = 5;
int dataPin = 6;
void setup() {
void loop()
long a;
shiftOut(a);
int pinState;
int outPut;
pinState = 1;
else
pinState= 0;
//stop shifting
The digitalWrite function is known to be slow (I read it multiple times on the arduino.cc forum itself). You can use the tlc5940 library, it is quite fast and uses bitbang or SPI to shift data in the register.
http://code.google.com/p/tlc5940arduino/ (http://code.google.com/p/tlc5940arduino/)
Thanks. I just switched to "true c" statements and it works great now.
int latchPin = 7;
int clockPin = 5;
int dataPin = 6;
void setup() {
void loop()
long a;
PORTD &= ~(1<<7);//digitalWrite(latchPin,LOW);
shiftOut(a);
PORTD |= (1<<7);//digitalWrite(latchPin,HIGH);
//delayMicroseconds(600);
int pinState;
//PORTD &= ~(1<<6);//digitalWrite(dataPin, 0);
//PORTD &= ~(1<<5);//digitalWrite(clockPin, 0);
int outPut;
for (outPut=24; outPut >= 0; outPut--) //24 different outputs
pinState = 1;
else
pinState= 0;
if(pinState == 0)
PORTD &= ~(1<<6);//digitalWrite(dataPin, pinState);
else
if(outPut == 0)
PORTD |= (1<<6);
else
PORTD &= ~(1<<6);
PORTD |= (1<<5);//digitalWrite(clockPin, 1);
//stop shifting
