Electronics => Electronics => Topic started by: Admin on February 17, 2009, 11:54:20 AM
This question has been asked several times before on SoR, but the previous threads didn't cover what I'm looking for. And they are ~1.5 years old . . .
Basically I want a wireless internet on a chip for under $50, that can communicate with an ATmega by serial, and is basically plug-n-play.
my laptop -> wireless internet -> internet on a chip -> UART of ATmega
All my laptop should need is the already built-in wireless card.
Some stuff I found that will work, but all too big:
http://www.ewiznet.com/goods_detail.php?goodsIdx=135
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=590-1041-ND
http://www.multitech.com/DOCUMENTS/Collateral/data_sheets/86002038.asp
must it be internet? Can it be a different form of communication
It must be internet.
I'm thinking the technology isn't here yet for wireless internet on a chip, so if I can't find anything I'll revisit this again in a year or two . . .
I'm afraid it doesn't meet your $50 criterium, but I just got a MatchPort wifi. Works great. I didn't get a chance to mess with it too much, but after about an hour I was communicating between my PC's terminal program and a micro via 802.11b.
http://www.cirrus.com/en/products/pro/detail/P46.html
+1 for Lantronix Matchport. That's what we use with the SRV-1 Blackfin robots. Cost is closer to $80, but it's the best deal around.
That's why I got it. If it's good enough for you guys, it's good enough for me ;D
Perhaps WiFly would do?
http://www.gridconnect.com/wifly.html (http://www.gridconnect.com/wifly.html)
but that isn't wireless :P
Anyway I looked into the MatchPoint . . . had entirely forgotten about it despite using hgordon's Blackfin . . . it's still a bit too large/expensive.
Made by the same company, there is this:
http://www.gridconnect.com/wiport.html
The size is much better, but the cost even higher . . .
Oh and a question. Some wireless networks require entering a password, or like when I was a student CMU required us to register our MAC address before we could use the net. Think this would cause me any problems with MatchPoint or any other device?
In terms of size/features, it seems exactly what I was looking for! Still pricey though (for the budget I set) . . . anyone used this before? Skimming through the datasheet it appears setup is 100% command line . . .
Do you know which option looks like this?
(http://us.st12.yimg.com/us.st.yimg.com/I/yhst-1569184714598_2037_2246985)
The part in the picture may be one of these 2 part numbers:
RN-111B-E = SMA standard end launch jack
RN-111B-R = SMA reverse polarity end launch jack
It all depends on the antenna model you get for it.
I hadn't seen WiFly before. I wonder if the SPI port supports higher throughput ? This is the actual manufacturer - http://www.rovingnetworks.com/rn-111.php
I actually have a few WiPorts which I'm not using - we switched to the Matchport because we needed the lower profile package. Send me an email if you want to make a deal on these - I might have 2 or 3 modules.
The MAC address is printed on a sticker applied to the module.
Also, the module will come up on a pre-configured IP address if no DHCP server is present on its preset subnet. One way you can set the module up is to set up an adhoc wireless connection from a laptop on the preset subnet. Configuration is then via the laptop's web browser. You can set security passwords, IP address, subnet, gateway, etc. there.
in the states they have a sd card for a camera that automatically uploads your photos to flicker maybe you could hack it
