Electronics => Electronics => Topic started by: mohamed on February 16, 2008, 03:28:28 PM
now after i complete the cerciut wireing and i connect the motors it doesnt move as it like the motor doesnt get any power only the green,red and blue LEDs are working but the motors doesnt
i connect the motor to pin 3 and 6 and the other one to 14 and 11 can anyone tell me what is wrong plz coz i spent alot of money and work on that project and it's so dissapointed to not to work
I think you have not connected the output of the sensors to the L293D.
Post pics of your circuit if possible so that I will be able to help you better.
hi dude...
same problem here...
motors are not working even though the leds are glowing...
my competitions is on the 20th
if you find a solution just notify me 2....
Do you have a multimeter or a volt meter at hand?
yea i have multimeter
i'll try to post any pic today
here is pic for my connections
Couldn't find any mistake in your circuit. But i'm not sure of the connections of the L293d.
Can you post the close-up pic of the L293d connections?
here is a close pic to the L293D connection
Have you connected the motor wires to the L293d?(They are not seen the picture)
i connect the motor to pin 3 and 6 (-ve pole to pin3 and +ve pole to pin 6 ) but it doesnt work
What about the other DC motor?
You have to connect one dc motor to pin 3 and 6 and the other to pin 14 and 11.
i solder both of them and nothing happened plz tell me what to do?
could anyone tell me what is wrong wiz this connection
here is a question do i have to solder pin 3 with pin connected to the male header same goes with the other pins or not?
PS: lots of ppl facing the same problem so plz dont ignore
could you post a photo of the top of the board aswell please so we can see how the polarity of the components are thanks :)
here is the top
From the picture which shows the top of the board, I see that you have not connected the sensor outputs to the L293d through the header pins. The procedure to do that is given at http://www.societyofrobots.com/member_tutorials/node/66 (http://www.societyofrobots.com/member_tutorials/node/66)
i did solder them coz i didnt find these sockets that attached to wires
but there is sth happened when i remove the two wires near the capacitor (to make the robot move white line follower) i was testing with one motor and when it moved i attached the other motor but when i switched on the ciruit again ,both motors weren't moving so what wronge happened?!!! ???
PS: do the motors need more voltage like battery of 12V or what?
What are the ratings of the motor you are using?
And also what is the specification of the battery you are using?
i'm using a 12v motor but it didnt say how much in the amps but it's number is (MMI-6S2L)
and i'm using a 9v eveready
Thats partly why its not working. You need a much better battery, like a NiMH or NiCad. A 9V probably can't power your motors.
