Electronics => Electronics => Topic started by: roboSonny on May 12, 2010, 11:36:41 AM
hi,i m trying to build a robot and a i don't know what controller to use and i need your help.i would like to control/programming it via bluetouth,to support 16 servos and to have ports for sensors,c-programming.thank you in advance..
AFAIK no microcontrollers have bluetooth built-in, so you'll need to get a separate module for that (be warned - they get quite expensive. much more expensive than the microcontroller itself).
Just about any microcontroller (that have enough outputs) will do.
meet the arduino bluetooth...
(http://blog.makezine.com/Arduino-BT-01-L.jpg)
It ISN'T made for beginners, get a duemillanove first, it has a very easy size to work with chip package, that can be replaced VERY easily if damaged, unlike the BT version.
