Electronics => Electronics => Topic started by: YoungGenius on March 25, 2010, 05:49:29 PM
How do I make a small sensor that I could put at the rim of a pot (over the stove) so that when it detects too much light it sets an alarm off?
It'd use and infrared detector like this (http://www.radioshack.com/product/index.jsp?productId=2049727) .
This will only detect IR light modulated at 38kHz. It will not detect a fire under the pot which is want I believe the OP wants to do!
A cheap and simple solution would be to use Light Dependent Resistor(LDR) or a photoresistor. Search the internet for the circuit. It is quite a popular circuit and should be available.
You will also have to some how insulate the sensor from the flame, so the the parts themselves do not catch fire!
You could use an IDR, but it go off from other souces of light. An IR detector will only sense IR which is given off by a flame. I'm not sure exactly what frequencies a flame gives of, but I don't think that wouldn't be to hard to find.
Yes, IR would work but that sensor blocks out anything above or below 38kHz which could cause problems. An ir sensor could work but it would need to be wide range.
How do I make a small sensor [...] when it detects too much light it sets an alarm off?
Many fire alarm systems include thermal detectors, as a quite effective means of detecting fire.
I don't know exactly what fire you wanna detect, the ones under the pot or those that may arise from forgetting your stew for too long (Which may sometimes only result in a glowing mass and black smoke).
In each case, a thermocouple bead could be a viable solution, as in any case, the temperature will rise rather quickly in case of a fire. Further, Thermocouple beads come in variants that easily cope with 1300°C.
smoke alarm??
Going off each day at dinner time ;D
HI,
i made a fire sensor for fire fighting robot competition which won both 1st and 2nd places.
I used a simple IR detector(one like 2SD400 transistor bt only with 2 pins) and a differential amplifier.it works very well.only draw back is its sensitivity greatly reduces with sun light.
http://www.sparkfun.com/commerce/product_info.php?products_id=9570 (http://www.sparkfun.com/commerce/product_info.php?products_id=9570)
bit pricy though
