Author Topic: negative voltage from 2 buffered sources?  (Read 1001 times)
« on: January 06, 2010, 02:22:16 PM »
i need to supply an op amp with +5v and -5v. if i have a single power source (i.e. a 9v battery) and 2 7805 voltage regulators would they be enough of a buffer to be used in the same circuit you would normally use with 2 9v batteries? (see the video below thoughtfully created by afroman).
Operational Amplifier Tutorial & super microphone circuit
Next step: Give them vaginas
Re: negative voltage from 2 buffered sources?
« Reply #1 on: January 06, 2010, 03:53:41 PM »
No, the 7805 needs 8V in and even if you discard that bit of info, 5+5 is usually 10 ;)
If you just wanna make a mic-amp., then you can just use the 9V and create an artificial ground (2 resistors and 2 caps should do in a nick).
Last post June 09, 2008, 06:09:22 AM
by BEAMer
Last post April 08, 2009, 12:43:24 AM
Last post June 13, 2009, 09:24:14 PM
by awally88
Last post February 10, 2011, 05:12:05 PM
by newInRobotics
