Author Topic: Using a different USB to Uart chip to flash the Axon II  (Read 2250 times)
Offline madsci1016Topic starter
  • Helpful? 43
« on: January 08, 2010, 04:12:32 PM »
Hey guys, i have a question before i go about ripping up an Axon II.
I really want to remove the USB chip and plug from my Axon II when i get it so can use Uart1 on my robot. I have a laboratory at work that could do it cleanly.
Will the FBOOT bootloader work with say a FDTI chip (a Arduino programmer) to flash over UART1? The idea being i can flash the Axon II in the same manner as a Arduino pro mini, where the usb -> Uart chip stays with the programmer.
 I really want to avoid using a software uart.
Re: Using a different USB to Uart chip to flash the Axon II
« Reply #1 on: January 08, 2010, 11:14:38 PM »
Uhh, i remember someone wrote code for the axon to work with arduino mega programmer, maybe this could work?
I don't think the axons fboot would work with the fdti chip though...
  • Helpful? 43
« Reply #2 on: January 09, 2010, 10:16:53 AM »
Well, i tried it with the fdti ship connected to just USB, and FBOOT didn't complain and i saw the TX light go crazy. (and the spinning thing on the command line was full speed again!!!! which it was not doing for the USB chip on the Axon. )
« Reply #3 on: January 09, 2010, 03:24:27 PM »
So, did it work?
  • Helpful? 43
« Reply #4 on: January 09, 2010, 04:28:06 PM »
Well, I would have to remove the USB chip from the axon and somehow solder on a pin header connector To test it. I just wanted to see if someone could tell me for sure if it would work or not...  Admin?
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
« Reply #5 on: January 09, 2010, 05:56:27 PM »
Use a programmer to load the Arduino Mega bootloader and use UART0 further with a FTDI Basic board. You can find the bootloader in this thread:
http://www.societyofrobots.com/robotforum/index.php?topic=8060.msg62620#msg62620
« Reply #6 on: January 10, 2010, 01:09:18 AM »
Yeap, it'll work. You may find soldering onto the tiny traces a pain, though . . .
