Author Topic: Making my own SEPIC dc/dc converter  (Read 1745 times)
Offline z.s.tar.gzTopic starter
  • Linux Guru
« on: January 15, 2010, 04:06:32 PM »
In this next chapter of my seemingly never ending quest to use solar charging with lifepo4 batteries, I need to make my own sepic converter circuitry.
I've been reading all the sites I can find on google, and I pretty much understand how they work, but I still have a few questions.
1. What do you use for the switcher? There are IC's for it, but they're all surface mount (which I don't have to tools to work with). Wikipedia also mentions using a mosfet transistor, but I don't understand how that can do switching.
2. Where is a good place to get formulas so I can calculate what parts I need? Lots of sites talk about the theory behind it, but don't actually give how to calculate for one.
Offline little-c
Re: Making my own SEPIC dc/dc converter
« Reply #1 on: January 15, 2010, 04:52:58 PM »
mosfet, h bridge tutorial says how they work.
do you get transistors?
a mosfet is a transistor. at least in effect.
basicly a current on the input (collector)pin drops the risistance, and lets current flow through the device(base and emitter pins)
horrible math/physics/chemistry stuff behind it, but don't bother with that ;)
  • Linux Guru
« Reply #2 on: January 15, 2010, 05:02:49 PM »
Ok, I get how the transistor works now (or at least I think)
This just leaves the eqations...
« Reply #3 on: January 16, 2010, 09:08:43 AM »
1. There are IC's for it, but they're all surface mount (which I don't have to tools to work with).
I linked you to a through hole SEPIC-able switcher IC a while ago!
They're used as the power switch, driven by a switch mode IC.
  • Linux Guru
« Reply #4 on: January 16, 2010, 09:24:46 AM »
That works for sepic too?
I thought it was only a linear regulator...
Well now I just feel like a noob. :P
Edit: I was looking at the wrong post... Facepalms all around.
the LT1513 is exactly what I needed, thank you very much. (even if it took forever for me to realize it)
« Last Edit: January 16, 2010, 11:33:49 AM by z.s.tar.gz »
Last post October 03, 2008, 01:45:05 PM
by Rebelgium
Last post October 10, 2008, 04:25:55 AM
Last post May 30, 2009, 07:53:50 AM
Last post January 06, 2010, 05:36:13 PM
by SmAsH
