Author Topic: Getting into surface mount - Hand soldering or reflow oven?  (Read 1223 times)
Offline z.s.tar.gzTopic starter
  • Linux Guru
« on: January 19, 2010, 04:46:20 PM »
I'm at the point where I really need to get into smd's, but I don't have a lot of money to do so.
I'm wondering which option is a better bang for your buck: Buying a hot air rework/soldering iron station, or modifying a toaster oven to do reflow?
They both seem to have their advantages and disadvantages, so I'm wondering what you as the community have to say.
Re: Getting into surface mount - Hand soldering or reflow oven?
« Reply #1 on: January 19, 2010, 05:01:52 PM »
Use your normal iron? As long as you have a sharp tip and some solder wick, it is amazing the things one can solder with just an iron  :D
Here was my first attempt at SMD, and it worked great. Only used an iron and some solder wick for the mega168.
Offline GearMotion
  • Helpful? 24
« Reply #2 on: January 19, 2010, 06:18:09 PM »
I like the automated assembly machine...
You can desolder with a hot air station, but not (not easily) with an oven.
« Reply #3 on: January 19, 2010, 06:47:20 PM »
As long as you dont want to go beyond leds, caps and qfp's you should be fine with a regular iron and a sharp tip.
  • Linux Guru
« Reply #4 on: January 19, 2010, 06:58:26 PM »
I think I'm going to go with soldering, as I would need hot air rework stuff anyways.
(btw, this is my 4th time trying to post)
Last post January 21, 2008, 04:30:17 AM
by Bubbles
Last post March 29, 2007, 01:28:46 PM
by nanob0t
Last post January 18, 2008, 12:41:02 PM
by airman00
Last post January 20, 2008, 11:25:14 AM
by airman00
