Author Topic: New 'bot idea, need some input  (Read 917 times)
Offline galannthegreatTopic starter
« on: January 22, 2010, 01:53:14 PM »
I am currently planning on developing a new 'bot. I want to make it along the lines of a micromouse style robot, using stepper motors as my drivetrain. I want to make it basic for starters (basic object avoidance). Then down the road I want to add to it to make it more advanced.
So, for starters I am toying with the idea of directly connecting a wheel the the shaft of the stepper or to use the gear that is on the motor to turn a geared wheel of some sort. What should I do?
Also I am trying to choose a driving method for the motor (it's unipolar btw), driver chip (good recommendation would be greatly appreciated), or premade board, or make a driver out of discrete components. Which route should I go?
Any input/ideas/recommendations would be nice.
Here is the motor I'm planning on using.
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=171601
« Last Edit: January 22, 2010, 03:54:55 PM by galannthegreat »
Kurt
Offline nottoooily
Re: New 'bot idea, need some input
« Reply #1 on: January 22, 2010, 06:17:32 PM »
You need to find out what speed and torque you want. That'll determine if you need gearing. If you try to make a gearbox be prepared for some precision machining or you'll easily get teeth jumping, breaking off or binding.
Offline Pratheek
« Reply #2 on: January 23, 2010, 05:22:01 AM »
From my experience bipolar stepper motors give better torque than unipolar steppers. I would suggest you use bipolar steppers.
For the driver you can use L293 or the L297/L298 ICs(L293 has less options, but it is cheaper and circuit is simpler than L297/L298).
« Reply #3 on: January 25, 2010, 02:33:30 PM »
Thanks for the replies.
@ Pratheek
Thanks, I'll look around and find a substitute. I also have access to some nifty driving chips for bipolar steppers.
The nifty chip:http://www.allegromicro.com/en/Products/Part_Numbers/3988/3988.pdf (either design a board with the amazing tools at my disposal, or get some Easy Drivers from sparkfun)
Possible substitute:http://www.sparkfun.com/commerce/product_info.php?products_id=9238
@ nottoooily
If I do a gearing method I'll use a wheel with a gear on the wheel itself, or just use direct drive. The direct drive method will be the more likely choice now that I'm looking at bipolar motors.
If you have any places in mind that have wheels with gears directly on them I would be in great appreciation of that. :)
Here is the kind of wheel that I'm talking about:
Kurt
Last post April 23, 2007, 10:36:13 PM
by JonHylands
Last post May 04, 2010, 09:46:28 PM
by Cristi_Neagu
Last post July 10, 2010, 02:27:14 PM
Last post November 13, 2010, 06:18:21 AM
by azy
