Author Topic: The New Fboot.exe Downloader->Ro0110.exe  (Read 10790 times)
Offline catalinene33Topic starter
« on: January 25, 2010, 02:45:30 PM »
I attached Ro0110.exe which replaces/includes Fboot.exe(v2.1) or Fboot17.exe with a user friendly interface.
I hope it will shorten the time required for testing.
Look at pics
Admin you can put it in the bootloader tutorials.
« Last Edit: January 26, 2010, 11:35:57 AM by catalinene33 »
Offline Ryltar
Re: The New Fboot.exe Downloader->Ro0110.exe
« Reply #1 on: January 25, 2010, 05:57:31 PM »
Does this work on 64bit Windows 7? I've been using my old xp laptop to program my bot for a bit because I couldn't get fboot17 working on my new system.
Offline madsci1016
  • Helpful? 43
« Reply #2 on: January 25, 2010, 06:29:18 PM »
I agree. This is / could be massively more useful if it was compatible with 64bit windows, but i have a feeling it's simply a skinned gui for fboot.exe.
« Reply #3 on: January 25, 2010, 09:00:27 PM »
Interesting!
Can you add some credit to yourself on it? I'd feel bad if it looked like I made it myself when I link it up!
I'll add it to the $50 Robot bootloader tutorial, as well as the Axon microcontrollers.
« Reply #4 on: January 26, 2010, 11:34:40 AM »
No is an application only for x86. Fboot.exe is the limitation.
Interesting!
Now has credit in the About button.
Offline Ryltar
« Reply #5 on: January 26, 2010, 02:31:26 PM »
Drat, well good thing I still have an x86 system.
« Reply #6 on: February 01, 2010, 03:07:35 AM »
The tutorial is now here:
http://www.societyofrobots.com/axon2/axon2_setup3.shtml
I noticed that the 8 character max file name bug no longer exists, not sure why . . .
Also, can you add 230400 to the baud rates?
« Reply #7 on: February 03, 2010, 09:07:45 PM »
Because the input file is copied to the temp with the name "default.hex"
Ok I will add the 230400 baud.
Offline Hero I
« Reply #8 on: June 12, 2014, 08:39:58 PM »
Technically you can run 32 bit Windows applications on a 64 bit Windows system.
We do it all the time at my work.
So, what is it with fboot that it won't work on a 64 bit system?
  • Helpful? 111
« Reply #9 on: September 28, 2014, 11:45:10 AM »
The problem is that the Windows DLL (native code plug in0 is different for 32 bit and 64 bit systems.
WebbotLib Studio copes with both 32 and 64 bit systems.
