Author Topic: How to set up a Maxstream RF Modem and Xbee Pro  (Read 2531 times)
Offline MagnusTopic starter
« on: January 28, 2010, 11:15:27 AM »
Hello,
I just received my new Maxstream USB Wireless Serial Interface XBP24-PKC-001-U http://www.elsist.it/WebSite/Ftp/Various/Maxstream/RadiomodemXBee/product-manual_XBee-PRO_USB_RF-Modem.pdf and a Wireless Serial Mobile Transceiver Module with xbee pro. Both from http://www.superdroidrobots.com/shop/item.asp?itemid=681&catid=54
(part number TE-070-001)
I installed the drivers per the instructions. The steps were a little different than what the instruction book said (I'm using VISTA) but, it said that my devices were ready. I performed the range test and it appears to work just fine.
I hope to use this wireless system to control servos on my robot. The range is incredible. I have two (Scott Edwards) Mini SSC II servo controllers and software called ROBO-WARE from website http://www.rentron.com/Robo-WareV2.htm and http://www.seetron.com/pdf/ssc2_mnl.pdf. This software allows me to use a serial cable to control up to 16 servos.
 I was hoping that this would be an easy "right out of the box and go" but, the Maxstream instruction book looks ominous and confusing to me. So far I can't get it to work. The manual says that it should act as a serial line replacement.
I have tested the SSC II's with the serial cable (the manual shows the pin out) that came with them and they work great.
The SSC II servo controller data sheet http://www.seetron.com/pdf/ssc.pdf says:
Serial input...............RS-232, or inverted TTL/CMOS, 9600 or 2400, N81
The Wireless Serial Mobile Transceiver Module with xbee pro has a TTL connector on it. So do I just need a TTL to RS-232 converter cable or what?
Could someone help me get the Maxstream setup so it will communicate with the Mini SSC II's?
Thanks in advance,
Rex
Project Magnus
Re: How to set up a Maxstream RF Modem and Xbee Pro
« Reply #1 on: January 29, 2010, 08:00:40 AM »
Yes, the Digi docs are not written for hobbyist. Try going the the Digi User Support forums and read every thread in the XBee sections. There is a lot of good information there that clarifies the Digi Doc's contents.
« Reply #2 on: January 29, 2010, 11:08:16 AM »
Thanks waltr. Did not think that they would have their own forum. I'll check it out.
Rex
« Reply #3 on: February 02, 2010, 08:43:13 AM »
Turns out all I needed was a TTL to RS-232 converter cable.
