Author Topic: Use standard laser measuring tool  (Read 1082 times)
Offline vultureTopic starter
« on: February 04, 2010, 03:12:02 AM »
Hi, I just got into the robot building buisiness and have a lot or reading and learning to catch up.
I was looking at the current range measuring possibillities used with current hobby robots and only did find the Sharp infrared sensors and the ultrasonic ones.
I also found the laser scanning ones but they cost the same as my car...so no option there.
I was wandering if it would be possible (or if someone has already done this) to use the laser distance measuring tools that are currently available in the tool stores.
something like this:
http://www.bosch-do-it.nl/boptocs2-nl/Doe-het-zelver/Gereedschappen/NL/nl/hw/Laserafstandsmeters/95299/PLR+30/11510/index.htm
It would be nice to be able to use something like this for the beam is much more narrow that the ultrasonic and infrared ones and thus more acurate...
anyone any ideas?
Offline madchimp
Re: Use standard laser measuring tool
« Reply #1 on: February 04, 2010, 07:18:49 AM »
Well since it's in a language I don't understand I can't be 100% sure but it looks like it is just a laser pointer and then uses an ultrasonic sensor to actually do the measuring. I actually have a unit very similar and is pretty handy for getting rough estimates.
Offline rgcustodio
« Reply #2 on: February 04, 2010, 05:16:42 PM »
http://www.bosch-presse.de/TBWebDB/en-US/Presstext.cfm?CFID=5253701&CFTOKEN=243fbde9d34fc9-E0F5B2D5-9B5C-8B40-59C88525DB1CD555&Search=1&id=2643
That should give you the English version (or something similar) of its relatives
It touts +/-2mm accuracy from 0.20m - 30m, and uses all laser technology. This baby is not for rough estimates.
The main issue with interfacing with home products is the proprietary nature of the connectors/interface (if any) and/or of the protocol. You will need to totally hack the product in order to get the data properly.
« Reply #3 on: February 04, 2010, 06:53:08 PM »
Hi
Everything is relative... Here's your option ;D
I was wandering [...]
Follow the link above and your wandering is a thing of the past  :P
[...] if it would be possible (or if someone has already done this) to use the laser distance measuring tools that are currently available in the tool stores.
anyone any ideas?
It's allways a good idea to post a link in the English language or point to a translator on the net (for those that find it hard to open the page in a translator themselves), but luckily, Dutch (as written language) is close enough to Danish (at least when you are schooled in Latin) that I can read about 95% of it and if I'm not mistaken, it's the very model I was drooling over in the local hardware store about a month ago.
In DK, it's around €220 to €240, so I let the store keep it (for the time being) as I wasn't really needing it.
It's about 10 times what the Ultra Sound variety costs (and they suck big time, so I'll probably convert mine to a 'bot sensor).
The Bosch is a LASER measure and while I haven't opened one, from the outside, it looks like it uses the same principle as the Sharp rangers (it could be phase lag oriented, but it looked like a CCD as the Sharp use them and TOF is not going to happen in a consumer device in a very long time, if ever). I've only tested it in the shop, but it seemed to be spot on and was not confused by nearby stuff.
As I haven't opened it, I can't say if it's easy to hack, but I assume most is handled in a DSP chip with no wires to tap - A µcontroller could read the LCD lines of course, but then we're talking serious design that you shouldn't even attempt until the time that you dream electronics design.
Perhaps you can get it much cheaper than the DK price, but as an alternative and much cheaper (as well as actually within reach of your electronics standing) idea, consider hacking a Sharp sensor and angle the detector a bit to get a larger range - and replace the LED with a LASER.
Btw. What kind of range do you need? (not want, but need, like... I want a car with 1000 HP, but I need a car able to get me from A to B in crowded streets).
The Sharp comes in several flavours, up to 5m IIRC and you only need that distance if you go fairly fast.
« Reply #4 on: February 05, 2010, 03:48:14 AM »
OK, thanks for the sugestions.
I understand that this kind of 'hack' is not for the faint-of-hearted, it was just a thought.
As I said, I'm fairly new to robotics, but I was looking for something more accurate than those sharp sensors.
From what I read in the documentation, their 'beam' is not very small and thus the accuracy is low.
I was really looking for a way to 'map' the room to be able to find a way from A to B.
I'm not finished reading all the theoretic stuff about this...
