Author Topic: Suitable alternative to the hs-311 50 dollar robot infrared scanner servo?  (Read 1252 times)
Offline BorotTopic starter
I have come across this little servo, Power HD Micro Analog Servo HD-1900A.
at this site, http://www.robotgear.com.au/Product.aspx/Details/375.
Is this a suitable alternative to the hs-311 for the 50 dollar photovore robot upgrade, as it's cheap to buy here in Australia.
cheers
Offline gaurav.p
  • Go robotics
Re: Suitable alternative to the hs-311 50 dollar robot infrared scanner servo?
« Reply #1 on: February 07, 2010, 06:04:52 AM »
post the link again,it isn't working ::)
"The page cannot be found"
-gaurav
Big Things Come In Small Packages!!!
« Reply #2 on: February 07, 2010, 06:10:24 PM »
Just remove the trailing period in the URL to get this.
Offline z.s.tar.gz
  • Linux Guru
« Reply #3 on: February 07, 2010, 06:13:11 PM »
The IR sensor isn't a lot of weight to move, so almost any servo that you can mount it to will work. (Within reason of course)
Offline Razor Concepts
  • Helpful? 53
« Reply #4 on: February 07, 2010, 06:35:50 PM »
That is a micro servo.. it will struggle under load. Get a standard sized servo.
Offline z.s.tar.gz
  • Linux Guru
« Reply #5 on: February 07, 2010, 07:46:51 PM »
There's no way micro servers can't move around two ounces of plastic that's only like an inch long.
  • Helpful? 53
« Reply #6 on: February 07, 2010, 09:35:12 PM »
I'm assuming that those are for the drive wheels? Can't really be sure, there really is no photovore upgrade because it is a photovore to begin with. For drive wheels micro servos won't be enough, but for an IR rangefinder (if that was what he meant) it should be fine.
Offline Webbot
  • Helpful? 107
« Reply #7 on: February 07, 2010, 11:19:07 PM »
Can you get a Hitech HS 322
Thats the original upmarket version of the 311 that has sort of been discontinued.
« Reply #8 on: February 08, 2010, 12:21:42 AM »
Just because its cheaper doesn't mean it'll save you money.
Think about what you'll have to spend if the el-cheapo servo you buy breaks or fries for no reason within just a few week of you using it. Its cheap for a reason! :P
The HS-311 is really reliable, I've owned like 20 of them over ~9 years and only one fried for no reason, and one broke a gear. Compared to most servos I've used, thats really good reliability.
« Reply #9 on: February 08, 2010, 04:49:21 AM »
I purchased the power (hd-1900a) micro servo already, i'll let you know if it fries. It does however drive(rotate) the tiny sharp infrared rangefinder and it's aluminium mount with ease. I think using a standard hs-311 or similar is better upon reflection as i can more easily reuse a standard servo for my next project.
Last post November 09, 2007, 09:32:56 AM
by Piyush
Last post December 07, 2009, 10:34:15 AM
by chelmi
Last post February 11, 2010, 06:20:45 AM
by hopslink
Last post January 10, 2011, 11:06:55 AM
by airuno2l
