Author Topic: Resistor - for 50$ robot  (Read 632 times)
Offline farsam1984Topic starter
« on: February 08, 2010, 01:00:26 AM »
Hi
Is it okay to use a combination of 2 or more resistors(in Series form) to get 340-ohm Resistor ?
i couldn't find 340-ohm and 1620-ohm resistors (i found some around that value such as 330-ohm)so i decided to assemble that way,Will it cause any problems?
Thanks for your attention
Re: Resistor - for 50$ robot
« Reply #1 on: February 08, 2010, 01:39:31 AM »
What is the application? Most times resistors don't have to be too accurate.
But yes, you can put multiple resistors together to make a higher resistance value.
  • Helpful? 107
« Reply #2 on: February 08, 2010, 02:15:04 AM »
Not sure what the scenario is but most resistors (unless specified) are + or - 10% anyway.
So for 340 ohm - a 330 ohm; for a 1620 ohm then a 1.6k (ie 1600 ohm) are probably ok.
Let us know where you get the figures from - and what they are used for - then we can give you thumbs up/down.
« Last Edit: February 09, 2010, 12:25:55 PM by Webbot »
« Reply #3 on: February 08, 2010, 03:42:03 AM »
http://www.societyofrobots.com/step_by_step_robot_step1.shtml 0_o?
Anyway, as Webbot said, most resistors close to the range will work. i used a 1.5k resistor on my $50 robot.
And for the 340ohm resistor, its for an led so anything around 200-400 should be fine...
Last post July 16, 2010, 06:31:22 PM
by Alfa_Zulu
Last post September 17, 2010, 10:01:46 AM
by GearMotion
Last post November 13, 2010, 11:55:02 AM
Last post February 28, 2013, 04:08:31 PM
by ValentineTodd
