Author Topic: Sharp Distance Sensor GP2Y0A02YK  (Read 4445 times)
Offline RatfinkTopic starter
« on: May 06, 2007, 11:17:16 AM »
http://lis.epfl.ch/contest/flying07/docs/resources/GP2Y0A02YK.pdf
Looking at the datasheet it says it roughly takes about 50ms for the sharp sensors to update each reading meaning i would be able to get a maximum 20 different readings per second is this bit correct?
I have a stepper motor with a stepper motor controller where each step equates to about 1.8 degrees per step. Hence if i want to take readings from between 0-180 degrees i would have to have a 50ms delay between each step to get a full sweep of readings. If someone can confirm my reasoning would be glady appreciated.
Offline hgordon
  • Helpful? 7
Re: Sharp Distance Sensor GP2Y0A02YK
« Reply #1 on: May 06, 2007, 02:02:48 PM »
Right - you could take 20 measurements per second.
There's more information on the Sharp detectors here-
    http://www.acroname.com/robotics/info/articles/sharp/sharp.html
It would appear that the beam width is approx 10 deg, so you could experiment with whether you get better results by overlapping successive fields (i.e. measuring every 5 degrees instead of every 10 degrees)
Surveyor Corporation
  www.surveyor.com
Last post May 10, 2007, 02:48:18 PM
by xamirx
Last post June 15, 2010, 03:58:25 PM
by gary_ramsgate
Last post January 26, 2013, 08:08:42 AM
by waltr
Last post January 28, 2013, 10:56:31 PM
by otai92
