Author Topic: $50 Robot Electronics- Status LED  (Read 1208 times)
Offline legobotTopic starter
« on: February 12, 2010, 11:05:35 PM »
I'm building the $50 Robot, and I'm at the stage where you test the electronics.  I have connected power to it, but the status LED isn't lighting up.  I have checked the dot schematic, and it says that the resistor the LED is connected to should connect to Pin 6 on the Atmega IC.  The instructions say to connect it to one of the digital outputs, though.  I'm getting really confused!
What should be connected where?  What should happen when I turn on the power?
If anyone could please answer these questions, I would appreciate it very much.
legobot
Offline Trumpkin
Re: $50 Robot Electronics- Status LED
« Reply #1 on: February 12, 2010, 11:11:28 PM »
The status LED will not light up until you program the microcontroller.
Robots are awesome!
« Reply #2 on: February 19, 2010, 03:02:31 PM »
Thanks Trumpkin!
So why is the LED connected to a digital output port?  Won't the LED only light up if there is power going to that port?
legobot
« Reply #3 on: February 19, 2010, 03:16:58 PM »
No, the led lights up when the port goes low, thus letting power from vcc through the led, though the pin to gnd.
« Reply #4 on: February 19, 2010, 07:53:16 PM »
Ah ha!
Thanks!  That makes sense.
legobot
Last post March 27, 2007, 01:39:43 PM
Last post June 05, 2007, 01:12:04 PM
by AZ196F
Last post June 04, 2008, 09:57:05 PM
by brian
Last post July 06, 2010, 04:44:21 AM
by Alfa_Zulu
