Author Topic: help...Need to make a wireless robot with camera  (Read 3416 times)
Offline manishrcTopic starter
« on: February 13, 2010, 09:13:58 PM »
hi all. I'm a beginner :D
i need to build a robot driving two wheels.(differential action)
controlled wirelessly through a laptop
transmit video from 2 cameras to the laptop(range 100m)
using arduino as speed controller
presently i'm using arduino to control the robot.
zigbee to control wirelessly
but cant use it to transmit video  :(
please suggest me what i can use to make those above possible.
a lesser range will do.
Re: help...Need to make a wireless robot with camera
« Reply #1 on: February 13, 2010, 09:27:55 PM »
Wireless cams!
Offline robotsRcool
« Reply #2 on: February 14, 2010, 12:24:47 AM »
Wow thats a big project for  a beginner
I'm just starting  out to and to me that looks really hard but good luck :o
Offline blackbeard
« Reply #3 on: February 14, 2010, 02:29:21 PM »
well if you don't need anything particularly fancy then you can get a wireless security camera kit from DX and just glue it on. you can also stick the camera on a servo swivel mount.
here is my arduino powered camera bot
http://s213.photobucket.com/albums/cc300/mashersmasher/?action=view&current=DSCN7257.jpg&newest=1
Next step: Give them vaginas
Offline Pratheek
« Reply #4 on: February 14, 2010, 09:38:39 PM »
Transmitting wireless video to a laptop will not be possible with those cheap wireless cameras. They give a AV output which you can connect to your laptop only through TV tuner card(unless your laptop already has one built in). And as far as I know for 2 cameras you will need two tuner cards.
You can buy wireless cameras which connect to your USB port directly, but these are difficult to find and costly.
My suggestion for you would be to use IP a camera.
« Reply #5 on: February 14, 2010, 09:58:51 PM »
I use a standard AV-out wireless system along with a EasyCap usb dongle. Plug in the audio and video wires into the EasyCap, fire up some software, and you can see and download the video coming from the camera.
Offline guncha
« Reply #6 on: February 15, 2010, 06:50:40 AM »
It doesn't seem that the thread starter has any interest in actually making the thing as this is the second identical post with no replies from him.
None the less, for the sake of conversation I'd still recommend doing this the hard way (read: the expensive way) by making the robot a self contained linux server that could run, for example, a web server with video feed and controls. This way it can be used from any computer anywhere in the world over internet. Nice, no?
Offline blackbeard
« Reply #7 on: February 15, 2010, 08:00:39 AM »
hmm i imagine it would be quite the explanation but i'd love to know how to do this. with $80 ARM laptops this would be a nice little project assuming you could find a linux distro to work on it.
Offline guncha
« Reply #8 on: February 15, 2010, 05:19:48 PM »
Yeah, those 80$ netbooks have enough power for the job. Linux seems to run quite well on ARM platform; there are many flavours available (including Android, that's actually a port of Linux (if I'm not mistaken, open source as well)). Only thing that would be required to make a surveillance robot with this thing is some usb webcams and probably some usb-i2c bridge so you could control the wheels and camera servos from the system.
The rest is software, that costs nothing (apart from time) and can be made to work no matter what. If you do decide to make one, I'd gladly help with this part.
Offline Gaganpreet
« Reply #9 on: February 15, 2010, 09:50:07 PM »
hey m also beginer plz tell me thathow to make it
Offline blackbeard
« Reply #10 on: February 17, 2010, 07:55:20 AM »
is there a way to use skype over lan? i may sound like quite the nub but i'd think that way you could not only have audio and visual but if you used an arduino with the USB library you could make it say things like "i have snagged myself on something" or "my batteries are low" as an IM which might be neat
Last post November 22, 2007, 10:59:02 AM
Last post February 21, 2008, 02:27:05 AM
by shadow57
Last post February 10, 2010, 12:23:17 AM
by Webbot
Last post January 11, 2011, 01:52:10 PM
