Author Topic: 50$ robot> PC motherboard protection  (Read 3097 times)
Offline razvanc_roroTopic starter
« on: May 07, 2007, 12:28:42 PM »
I've understand that if something is going wrong in the circuit, I could do the "smoke test" on the PC's motherboard. Also found out that there is some components that I might use to save "my precious" from being turned into ashes  :D :
ST202EC or ADM3202
If anyone knows about this, let me know. Or this circuit it's too easy for making a foolish mistake.
Thank you!
Greetings from Romania!
Try do your best without doing anything! Possible?!?
Re: 50$ robot> PC motherboard protection
« Reply #1 on: May 07, 2007, 01:15:56 PM »
hmmm thats a good question.
I believe both recommended AVR programmers have a built in protection circuit (especially the more expensive Atmel one) . . . but I could also be wrong . . . does someone know for sure?
Worst case scenario you will only end up damaging your serial port.
If you are using a serial to USB converter, it is almost guaranteed to have a safety buffer built in.
Anyway, before plugging in your circuit to your PC, you should always use a multimeter to make sure all the pins are doing what they are supposed to do. :P
Offline JonHylands
« Reply #2 on: May 07, 2007, 02:12:35 PM »
I fried a $500 PDA by connecting +5 volts to the ground line on the TTL level serial port.
- Jon
« Reply #3 on: May 07, 2007, 02:25:30 PM »
ouch.
Offline ed1380
« Reply #4 on: May 07, 2007, 02:34:49 PM »
been doing a bit of   ;)
« Last Edit: May 07, 2007, 02:35:54 PM by ed1380 »
Offline JonHylands
« Reply #5 on: May 07, 2007, 02:51:24 PM »
No, just a case of using a 3-pin molex connector to plug into a 4-pin connector. I had a momentary lapse of reason, and plugged it off-by-one.
So, after that I decided I would never again be lazy - even if I didn't need the fourth pin, it would be on the connector anyways...
Some lessons you have to learn the hard way.
- Jon
« Reply #6 on: May 08, 2007, 11:33:12 AM »
Thank you all for replying my message! Your answers replyed my questions.
Keep in touch!
Bye!
Last post July 05, 2008, 07:53:04 AM
Last post July 02, 2008, 06:52:09 PM
by airman00
Last post January 17, 2009, 01:35:30 PM
by Webbot
Last post June 02, 2009, 11:11:13 PM
by guru
