Author Topic: $50 Robot query  (Read 732 times)
Offline robakerTopic starter
$50 Robot query
« on: February 20, 2010, 07:06:34 AM »
What is the appropriate voltage for the circuit ?
In case 1: Its written to provide 6V ( both for 2 servos and the circuit)
while in case 2 : 4.8 V for servos and 9V for circuit.
Thus, why 9V in case 2 why not 6V ?
Re: $50 Robot query
« Reply #1 on: February 20, 2010, 08:08:39 AM »
Because a PP3 battery is a small package and since you need 5V, you have to regulate it down.
A 9V battery goes down to 5.4V when flat.
Re: $50 Robot query
« Reply #2 on: February 20, 2010, 08:31:47 AM »
if 5V is needed that could be obtained by 6V battery/supply as done in case 1 with 5xAA NiMH. plz if you could explain such concepts of voltages as for beginners may be beneficial.
Thank you for replying.
Offline cyberfish
Re: $50 Robot query
« Reply #3 on: February 20, 2010, 01:35:52 PM »
It's difficult to get 5V from a 6V battery because normal regulators (LM7805) require about 2V dropout (to provide a constant 5V, input needs to be above 7V).
To get 5V from 6V you will need a low-dropout regulator (LDO), which has weird output capacitor requirements to be stable, or a switching regulator, which also require external components, and are quite a bit more expensive.
Re: $50 Robot query
« Reply #4 on: February 21, 2010, 08:22:35 AM »
5 NiMH cells are 5*~1.45V = ~7.25V when fresh from a charger and considered flat at 4.5V to 5.5V, depending on the current draw.
7.25 is way too much for the controller so you need to add (LDO) regulator.
Last post August 27, 2006, 07:36:16 AM
Last post October 26, 2007, 09:35:34 AM
Last post February 10, 2011, 12:48:24 PM
by richiereynolds
Last post April 06, 2013, 05:11:57 PM
by FlyingPoncho
