Author Topic: 50$ robot> servo modify  (Read 5359 times)
Offline razvanc_roroTopic starter
« on: May 08, 2007, 01:14:33 PM »
I'm a novice in programming the microcontroller and I found out that the servos are being modified by this... How do I send the signal to sorvo to make 0 degrees on the gears?
Also I want to ask you if I could make this after building the whole robot and turning it on.
Thank you!
Try do your best without doing anything! Possible?!?
Offline hazzer123
Re: 50$ robot> servo modify
« Reply #1 on: May 08, 2007, 01:21:53 PM »
It depends which microcontroller.
You will need to make a delay of about 500 uS.
Then you turn on the signal pin for the servo --> call the delay --> turn off the signal pin
Repeat this a couple of dozen times a second.
For different angles, you could great a 8uS delay and loop it a number of times. This would be added onto the 500uS delay.
Using 8uS means you have the range of 0.5 - 2.5 mS in 256 steps.
Harry
www.icrobotics.co.uk
Offline ed1380
« Reply #2 on: May 08, 2007, 01:59:02 PM »
 or use 35 cpu cycles. 20-50 control angle.
Offline hazzer123
« Reply #3 on: May 08, 2007, 02:01:24 PM »
Won't the length of the cpu cycle differ between microcontrollers?
Offline ed1380
« Reply #4 on: May 08, 2007, 02:07:33 PM »
if you use the same mcu it won't
Offline hazzer123
« Reply #5 on: May 08, 2007, 02:27:24 PM »
oh yeh haha  8)
Didnt realise it was the $50 robot.
