Author Topic: new avr assembly compiler - is there any demand?  (Read 2225 times)
Offline z.s.tar.gzTopic starter
  • Linux Guru
« on: February 24, 2010, 11:00:28 AM »
I don't know how many people actually use assembly anymore so I just wanted to get a feel before I started working on making a new compiler.
When I say "new" I really mean I'm going to pick up the AVRA project that was abandoned in 2007 and change it up a little.
Offline HyperNerd
  • N3rd1n80r
Re: new avr assembly compiler - is there any demand?
« Reply #1 on: February 24, 2010, 01:39:57 PM »
I don't really think that many people use assembly anymore as its far too complicated for a beginner to learn.
Saying that however, I can think of some projects I saw on YouTube which use assembly because it allows much greater control over timing and the like.
I tried to learn assembly when I first got into PICs, but soon gave up as after around a full day of failing, I achieved a flashing LED on a breadboard.
I then gave MikroBasic a try, and within 2 hours, had an electronic dice and a UART example set up. Much more success!
I can understand why some coders prefer assembly, as they can optimise their code more then if the same code was generated with an IDE, but I don't think it is really worth the effort of making a "new" compiler for assembly language.
 -HyperNerd
There are 10 types of people in the world - those who understand binary, and those who don't.
Offline GearMotion
  • Helpful? 24
« Reply #2 on: February 24, 2010, 01:40:57 PM »
The subject of making a BASIC for the msp430 came up on the msp430 list. My reply was to make an assembler with some BASIC-like augmented commends. Here is what I posted. I think it would be valid for an AVR assembler, too.
> Here is what you should do, if it was up to me to decide what you
> should do with your time. :-)
> I used an assembler for the z80 once that was 'augmented' for lack of
> a better term. It was a macro assembler that had some nice macro
> functions to it.
> It still let you write plain assembly language code: (I'm making up a
> little syntax here)
>     Load A, 15
>     Mov A, PortB
> But it also let you write loops that translated into assembly: (I
> don't remember the exact syntax.)
>     DB loopy
>     For loopy = 1 to 100
>      Load A, loopy
>      Mov A, PortB
>     Next loopy
> A register was pushed/popped to support the macro.
> It had string functions and other "high level" constructs that would
> assist in writing assembly. It was an assembly/BASIC mix. I can't tell
> you how easy it became to write a lot of assembly. The output of this
> actually fed into a 'regular' assembler. This was all DOS-based, mind
> you, because it was about a hundred years ago when I wrote z80 code
> for money. My DOS text editor shelled out to run a batch file that
> called both the macro converter and assembler.
> I used this z80 basic/macro program a lot and I think I only utilized
> half of what it could do. IIRC you could use the macro language to
> manipulate 8/16/32 bits. Also single bit functions. I used the
> for/next and other constructs a lot. I think there was a limit on the
> depth that you could nest them, like 8 or so. It actually taught me
> structured programming - somewhat. I had to at least plan...
> I remember it was easy to make a subroutine that passed parameters, so
> I made a lot more subroutines because of that. And reading data out of
> an array (therefore incrementing pointers) was so easy that my code
> there never had bugs.
Offline billhowl
  • Helpful? 32
« Reply #3 on: February 24, 2010, 07:43:22 PM »
There is a active AVR assembler call "Gerd's AVR assembler"
http://www.avr-asm-tutorial.net/gavrasm/index_en.html
Why start a new one?
  • Linux Guru
« Reply #4 on: February 26, 2010, 12:26:13 PM »
Like I said I'm not really starting a new one just picking up where an old one left off.
I was going to pretty much fix some bugs and add new device compatabilites, but I think I may also add some libraries in too.
This is just something I was going to do for myself and I was seeing if anyone else was interested.
I guess I'm just a dying breed of asm developers. :-\
Last post January 22, 2007, 06:37:06 AM
by JonHylands
Last post February 16, 2008, 06:05:50 PM
Last post June 19, 2008, 04:35:46 PM
by benji
Last post January 31, 2009, 06:58:54 PM
by galannthegreat
