Author Topic: Sensor to computer  (Read 1330 times)
Offline zabuza™Topic starter
Sensor to computer
« on: March 02, 2010, 07:04:16 AM »
hi i was wondering if this would work.
i want to connect sensors to computer without going through a micro controller. i did some research and i need an a/d converter but i don't know what else to use.
Offline Hewhowalk
Re: Sensor to computer
« Reply #1 on: March 02, 2010, 07:21:19 AM »
You need some sort of logic that is responsible for transmitting the data in a way that the computer can interpret (protocol). But I would recommend you to make it easy and buy a interfacecard of some sort with all tha logic and circuit ready-made. Google "the namn of your sensor +computer interface" and you shouldd find something useful.
  • Helpful? 84
« Reply #2 on: March 02, 2010, 09:38:48 AM »
A micro controller really is the easiest way to do this. I would use a PIC that has analog inputs (ADC ) and a UART. Axon and many other processors have this capability.
Offline Hewhowalk
« Reply #3 on: March 02, 2010, 11:12:59 AM »
I would recommend using a Arduino Duemilanove. Extremly easy to use, and would work with most analog sensors.
« Reply #4 on: March 02, 2010, 12:26:22 PM »
true but i don't want to use a micro controller
« Reply #5 on: March 02, 2010, 12:35:50 PM »
iam using a photocell as my sensor. http://www.societyofrobots.com/schematics_photoresistor.shtml
Offline chelmi
« Reply #6 on: March 02, 2010, 12:57:21 PM »
Why?
  • Helpful? 84
« Reply #7 on: March 02, 2010, 01:03:00 PM »
Ok, then the next option is a data acquisition card to plug into your PC's bus.
Here are some examples:
http://www.omega.com/literature/transactions/volume2/dataacq2.html
http://www.dataq.com/news_releases/di410nr.htm
http://www.ni.com/dataacquisition/
And this thread is asking the same question:
http://www.societyofrobots.com/robotforum/index.php?topic=10490.0
« Last Edit: March 02, 2010, 01:05:26 PM by waltr »
Offline chelmi
« Reply #8 on: March 02, 2010, 01:25:02 PM »
You should mention the price of these babies (the cheapest is probably around 300 bucks), I'm pretty sure the OP will reconsider
the micro-controller solution. The phidget solution I quite expensive as well IMO.
  • Helpful? 84
« Reply #9 on: March 02, 2010, 02:28:48 PM »
Yep, but that's the alternative to using a microprocessor and programming it yourself.
Off the shelve solutions are faster to get running but do cost more. The OP wanted fast and not to build anything.
The Dataq device I linked to is only $24.95. Very cheap for what it does.
Offline chelmi
« Reply #10 on: March 02, 2010, 02:33:24 PM »
I missed this one in your list! nice find.
« Reply #11 on: March 02, 2010, 04:01:11 PM »
You don't need an A/D-C if you just wanna detect if there's a certain amount of light or not (like in a line follower).
If you have a parallel port it could hook up to that and with a few extra components, a serial port could be used.
« Reply #12 on: March 02, 2010, 04:09:34 PM »
just a serial port? surely u would need a/d converter to analyse the signal.
my idea is to send signals from the light sensors to the computer which sends signals by analyzing that data to motors to decide whether to move left right forward.
« Reply #13 on: March 02, 2010, 04:14:17 PM »
how would the wires physically fit into these daqs, would you have to modify the wires? so it would fit into their ports?
« Reply #14 on: March 02, 2010, 04:40:07 PM »
Oh well, if you know better, then don't listen to me.
What is it you wanna get from analyzing it?
If you want to decide whether you're over a white or black area, you only need to see if you have more than so-and-so-much light reflectance - using an A/D-C for that is bordering the downright silly and it adds a huge amount of overhead.
« Reply #15 on: March 02, 2010, 06:17:15 PM »
xd iam just saying lol
yeh tats pretty  much what i want to do. a line following robot following white line over black area without using a micro controller
« Last Edit: March 02, 2010, 06:20:59 PM by zabuza™ »
« Reply #16 on: March 03, 2010, 07:08:21 PM »
Then this circuit should do.
  • Helpful? 84
« Reply #17 on: March 03, 2010, 09:36:48 PM »
« Reply #18 on: March 04, 2010, 04:14:14 AM »
Or this one:
To stay within specs for the EIA/TIA-232, the signal has to stay within +/-3V minimum at the receiving end, with -V being "mark" or "1" and +V being "space" or "0".
How would you accomplish that with the circuit you point to?
  • Helpful? 84
« Reply #19 on: March 04, 2010, 08:32:47 AM »
It'll do that. Scroll down to the second schematic.
« Reply #20 on: March 04, 2010, 08:41:16 AM »
You did see the
[...] i want to connect sensors to computer [...]
The circuit you point to is just an H-bridge with LDRs, no PC connection like the OP wanted.
Last post March 26, 2008, 03:06:36 PM
by AndrewM
Last post September 24, 2009, 11:45:19 PM
by galannthegreat
Last post October 05, 2009, 10:57:49 AM
Last post April 12, 2011, 08:59:29 AM
by mstacho
