Author Topic: Microcontroller Help  (Read 1183 times)
Offline JarydTopic starter
« on: March 03, 2010, 07:12:13 PM »
Hi...
I just began soldering the $50 robot board... but i failed. I tried my best and went slow and all that but i am just having some problems. I now want to just buy a microcontroller so i can save some time and money. I looked at the roboduino but im not sure if i should buy the fully assembled one or the  kit. I dont quite understand the extent of what the assembly requires. So basically if you could help me figure out which one to buy or if there is a different microcontroller that would be better you could tell me that.
Thanks for your help.
Re: Microcontroller Help
« Reply #1 on: March 03, 2010, 07:47:27 PM »
I bought the roboduino assembled version and kinda regret it because i could solder well.
If your soldering is very bad, go for that option.
The roboduino is great for beginners, really just plug in and play.
I wouldn't suggest the arduino as its just too much trouble to get going with robotics.
« Reply #2 on: March 03, 2010, 08:36:28 PM »
Ok thanks... Is there any special software or wires that I will need to connect it to my computer and to program it?
« Reply #3 on: March 03, 2010, 08:39:53 PM »
You will need to download arduino software if you don't have/don't want to use a hardware programmer.
Windows: http://arduino.googlecode.com/files/arduino-0018.zip
Mac: http://arduino.googlecode.com/files/arduino-0018.dmg
Linux: http://arduino.googlecode.com/files/arduino-0018.tgz
The roboduino comes with a usb cable, this is all you will need to program it if you use arduino software.
  • Helpful? 84
« Reply #4 on: March 03, 2010, 09:35:12 PM »
Could you post pictures of what you have so far?
Maybe we can help you get this going.
« Reply #5 on: March 04, 2010, 04:50:46 PM »
Im sorry but i couldnt get a picture from my camera to work so i just made a quick video.
Basically i soldered 2 pins together and can't get them un soldered.
Yea its bad quality:(
« Last Edit: March 05, 2010, 03:56:37 PM by Jaryd »
« Reply #6 on: March 05, 2010, 01:27:42 AM »
Damn man, your camera needs some bad-ass glasses or something!
But have you tried desoldering braid or a solder sucker?
« Reply #7 on: March 05, 2010, 05:41:40 AM »
No... I will look up how to do that
thanks I will try a better picture after school today
Offline GearMotion
  • Helpful? 24
« Reply #8 on: March 05, 2010, 06:26:59 AM »
If you can't find solder braid, try this: Find some fine-stranded, heavy gauge wire and use the solder of your connection to 'tin' the wire.
Use a stranded wire that has a lot of very fine copper strands. What some call zip cord or lamp cord that is used for making/repairing lamps. Many hardware stores carry this. Strip off a centimeter or half inch of the insulation. Dip it in liquid flux if you have any. Then heat the solder and the cord on your connection. Some of the solder will be transferred from your connection to the wire.
Hopefully enough is removed to be a benefit.
« Reply #9 on: March 05, 2010, 02:11:42 PM »
By the way im going to radioshack to see if they have desolder braid or a pump.
« Last Edit: March 05, 2010, 02:19:02 PM by Jaryd »
Offline GearMotion
  • Helpful? 24
« Reply #10 on: March 05, 2010, 02:25:14 PM »
They used to have both.
« Reply #11 on: March 05, 2010, 02:28:14 PM »
The good ones should have it, some of the newer ones don't.
« Reply #12 on: March 05, 2010, 03:58:03 PM »
Yea i got a heated pump a normal pump and some desolder braid so i can figure this out. Thanks for all of your help. :)
« Reply #13 on: March 05, 2010, 05:35:14 PM »
My soldering iron just mad a pop sound and started sizzling. I unplugged it. By the way I bought it Tuesday. Is it safe to use??
« Reply #14 on: March 05, 2010, 05:41:58 PM »
Turn it on and see... Pops, generally aren't good but the only real way to tell is to turn it on.
If something bad happens, unplug it...
Last post February 02, 2007, 07:47:27 AM
Last post June 05, 2007, 09:58:31 AM
by rgcustodio
Last post August 03, 2007, 09:56:31 AM
Last post September 22, 2007, 03:03:27 PM
by h3ro
