Author Topic: Will these 433MHz radio transmitter and receiver pair work with a Mega  (Read 2260 times)
Offline Joker94Topic starter
  • Helpful? 26
hi every one
I have recently discovered that my local electronics store sells a transmitter and receiver both operating at 433 Mhz. I know for sure that they work with a PIC but i am  not sure if they will work with a Mega.
For the transmitter i am guessing i will hook up power and ground and connect the tx line to the data out put. As in the following data sheet. and the antenna to ANT
http://www.jaycar.com.au/products_uploaded/ZW3100(mod).pdf
As for the reciever i am not sure as there are 2 Data lines?
http://www.jaycar.com.au/products_uploaded/ZW3102(mod).pdf
My main question is would it be possible for me to use these with a Avr, i have been told that they are reliable, have a range up to 100m and for the both of them are only 26 dollars.
Thanks for your time
Joker94
Offline hopslink
  • Helpful? 14
If they work with a PIC then they should work fine with an AVR. They are a basic OOK pair so whatever digital state the Tx input is, the Rx output should match - provided you don't exceed the maximum data rate.
  • Helpful? 26
great, thanks for your help hopslink.  i will post my progress
 ;D
Those two data lines are connected internally, so you can pick and choose between which one you will use since it won't matter.
Offline billhowl
  • Helpful? 32
VirtualWire
Interface Arduino to low cost RF wireless modules to provide high performance transmitters, receivers and transceivers for data. Circuit diagrams and documentation and download instructions here.
  • Helpful? 26
Billhowl, thanks alot for that.
Picking them up in about an hour ;D ;D
  • Helpful? 26
well got them and built some modules for them and ready to test some basic operations over the next few days
