Author Topic: power switching  (Read 1479 times)
Offline TravelingPencilTopic starter
power switching
« on: May 10, 2007, 05:54:09 PM »
http://www.angelfire.com/80s/sixmhz/cgkit.html
I was wondering what they ment when they said that you could use the existing flash tube as a "trigatron" to switch the high voltage and current in step 3. what do they mean by switching?
PS i did google and wikipedia the trigatron
Offline Brandon121233
Re: power switching
« Reply #1 on: May 11, 2007, 04:04:21 PM »
notice the quotes around "trigatron"- meaning it probably is just a made up word. Anyway basically I think he means your utilizing the Xenon flash as sort of a trigger, when you start dealing with high voltages-things tend do get a little unstable, and in this case spark. If you used a normal switch, every time you flipped it, it would make a spark just before the connection closes. This little spark would cause great wear and tare on the switch. Using the flash- its the gas Xenon that completes the gap and the spark wont hurt anything.
However seeing as how the tutorial is not very good anyway- this is just my guess as to what "trigatron" means. Hope that helped.
        —Thomas Edison
Last post February 07, 2008, 08:39:31 AM
Last post February 02, 2008, 07:57:38 AM
by Rebelgium
Last post July 07, 2010, 01:02:43 PM
Last post August 11, 2012, 03:19:08 AM
by august
