Author Topic: {fixed} Microcontroller seems dead  (Read 677 times)
Offline ksquaredTopic starter
« on: March 05, 2010, 02:54:25 PM »
I have a microcontroller programmed for the $50 bot.  (Or thats what AVR studio says.)  However, the LED does not come on and it does not display any other response... truth be told, I have it on a breadboard without any of the peripherals.  How does one 'initilize' it?  (Atmega168.. they didn't sell any eights when I bought it.)
Thanks!
« Last Edit: March 07, 2010, 10:04:06 PM by ksquared »
Offline billhowl
  • Helpful? 32
Re: Microcontroller seems dead
« Reply #1 on: March 05, 2010, 06:53:26 PM »
You need to program it before the LED can come on, read this
http://www.societyofrobots.com/step_by_step_atmega168_swapout.shtml
It Compiles, Lestways...
« Reply #2 on: March 05, 2010, 08:47:16 PM »
Thanks, I did all that, it STILL seems not to work.  I mean AVRstudio still seems to program it, however, after that it is always dead.  For mechanical convenience (this is a breadboard) my unplugged programmer is still under the hood (y'know, connected.)
After Programming, I simply disconnected the circuit's power, took the USB out of the programmer and re powered the micro controller.
I mean, could I have hooked something up wrong and get that far?  All my wiring seems right.
Gracias.
« Last Edit: March 05, 2010, 08:56:14 PM by ksquared »
Offline billhowl
  • Helpful? 32
« Reply #3 on: March 05, 2010, 10:18:41 PM »
May you post some photos of your setup?
« Reply #4 on: March 07, 2010, 08:09:38 PM »
Actually... could it be my programming procedure?  From AVRStudio, I usually just upload the .hex file to FLASH.  Should I worry about ELF or EEPROM?  Using a voltmeter I determined that there is no voltage between pin 7 and pin 6.  Even if I unpower the controller after programming...
Does it hurt that the unpowered programmer is still plugged in?
And if it would still help, I might be able to figure out a way take a picture of the thing.
Though thanks alot!
Solution: LED_on() != LED_off()
« Last Edit: March 07, 2010, 10:04:47 PM by ksquared »
Last post August 13, 2009, 02:44:26 PM
by sonictj
Last post May 10, 2010, 03:07:33 AM
Last post October 12, 2010, 12:54:32 PM
by KurtEck
Last post August 21, 2011, 08:49:56 PM
by jonagik
