Author Topic: servo modification - tutorial query  (Read 1671 times)
Offline CradboardTopic starter
« on: March 09, 2010, 06:36:08 AM »
http://www.societyofrobots.com/actuators_modifyservo.shtml
i realise this is probably very basic but all i have at the moment is a box of bits and instructions telling me to plug my servo into the controller and send a signal to zero it?  this i do not understand!
obviously i have found the above post but i am unsure about zeroing the servo?  i havent got any software on my comp yet? do i need to download stuff to zero it? i am a newb and am following the guide but im stuck already!!   ??? ???
cheers
« Last Edit: March 10, 2010, 03:00:56 AM by Cradboard »
Offline Conscripted
  • Helpful? 10
Re: servo modification - tutorial query
« Reply #1 on: March 09, 2010, 08:42:18 PM »
You are going to need to tell the servo to "go to the centered position" before you can adjust the Potentiometer. You could use the microcontroller you build for the $50 robot to do it. You could also use basic R/C hobby stuff. The process is covered in step 5 of the tutorial you linked.
Conscripted
« Reply #2 on: March 10, 2010, 02:59:15 AM »
i have read that but given that this is apparently the first step in building my robot im confused!
do i need to build the controller and have the code written and have it plugged into my comp in order to modify the servo?
thanks
« Last Edit: March 10, 2010, 03:00:31 AM by Cradboard »
« Reply #3 on: March 10, 2010, 05:30:21 AM »
Yes, you have to make the controller first to be able to center the servos.
« Reply #4 on: March 11, 2010, 03:32:11 AM »
ok i have built the circuit board now.  so how do i zero  the servo?
Offline Joker94
  • Helpful? 26
« Reply #5 on: March 11, 2010, 03:39:17 AM »
down load the .hex file from the modification page and load it to your muc. when this is done you can work through the rest of the tutorial.
