Author Topic: TPA81 and AXON 2  (Read 1821 times)
Offline teoxanTopic starter
TPA81 and AXON 2
« on: March 10, 2010, 04:43:15 PM »
Hello,
I'm a happy owner of an Axon 2 for the last week, I have already tried some sensors and everything works good. :)
I have the TPA81 thermal array sensor from Devantech, an amazing little sensor that can even produce a thermal image of an
environment with the apropriate software.
However, it uses I2C and I need 4 pins for that ( 5V, GND, CLOCK and DATA).
Instead, the I2C pins in Axon 2 are only three.
I know it may sound stupid, but how can I actually plug it on Axon 2 ?
In my other microcontrollers ( Brainstem and Wiring ) I have succesfully used it.
Thanks!
Theo
Re: TPA81 and AXON 2
« Reply #1 on: March 10, 2010, 04:49:41 PM »
The axons 3 pins are gnd, data, and clock, so you will need to hook up the 5v from the TPA81 to a 5v regulated pin on the Axon.
Just wondering, is the TPA81 basically a thermal infrared camera with 8x1 resolution?
« Reply #2 on: March 11, 2010, 12:02:35 AM »
Thanks!
Well, you can say that it's an infrared "camera" with the resolution you mentioned, in the sense that you can create a thermal "image" of your room.
One of my thoughts about this, is buying 3-4 of them and have them swap an entire room, send the data to a PC and watch the outcome.
The only caveat is that they are expensive!
Theo
