Author Topic: Alternative to welding  (Read 5413 times)
Offline rockroboticsTopic starter
« on: March 11, 2010, 03:06:58 PM »
I wanted to connect coat hangers together, but I don't have welder.  Is there some sort of alternative to welding that is cheap?  Please answer me!
Thanks,
Rock Robotics
Rock Robotics
Technology of the Future!
Offline Jdog
Re: Alternative to welding
« Reply #1 on: March 11, 2010, 03:23:46 PM »
Well you can braze it.
http://www.societyofrobots.com/mechanics_brazing.shtml
Or, depending on the application you might even be able to solder it.
« Reply #2 on: March 11, 2010, 03:30:49 PM »
Thanks, this sounds like a good idea!
Rock Robotics
« Reply #3 on: March 11, 2010, 04:34:39 PM »
If soldering (or epoxying), wrapping with thin wire first will give added strength.
Metal coat hangers could perhaps just be twisted hard together (with pliers).
Offline little-c
« Reply #4 on: March 11, 2010, 04:56:40 PM »
if you have a grinder (I have done this with a file, to prove it could be done),
take the two ends of the wire,
grind lengthways an L shape in the wire, so when put together it forms one bit of wire, with an overlap.
epoxy/solder/braze that together.
then wrap with thin wire and epoxy/solder/braze that.
when wraping with wire, tight close in binding for strength, slightly loser if strength isn't an issue, but is just subject to vibration.
« Reply #5 on: March 11, 2010, 05:10:24 PM »
Thanks,
That's a good idea but would a soldering iron be hot enough to do it?
Thanks,
Rock Robotics
Rock Robotics
« Reply #6 on: March 11, 2010, 07:38:49 PM »
If 50W or higher it should do, but otherwise, a flame will help - eg. one of the "turbo" lighters with a pointy flame (and something nonflammable and isolating to go on the table), just be extra carefull when operating with an open flame!
« Reply #7 on: March 11, 2010, 07:52:41 PM »
Cool thanks!
Yor like helping everybody on this site!  Thanks!
Rock Robotics
Offline mgargiullo
« Reply #8 on: March 12, 2010, 12:09:08 PM »
Rock, if you get stuck and are in the central NJ area, I've got a MIG welder.
« Reply #9 on: March 12, 2010, 01:35:03 PM »
He's 6 timelines from you.
Offline GearMotion
  • Helpful? 24
« Reply #10 on: March 12, 2010, 03:00:58 PM »
Wow. NJ is big!
:-P
« Reply #11 on: March 12, 2010, 04:05:10 PM »
Wow this is kinda wierd and cool!
I live in NJ!  Sussex County!
And by the way my middle name is Rock! SRSLY
Rock Robotics
Rock Robotics
« Reply #12 on: March 12, 2010, 04:07:40 PM »
Hey Soeren,
I don't get what your talking about!
Six timelines?
Rock Robotics
« Reply #13 on: March 12, 2010, 08:43:53 PM »
Hey Soeren,
Six timelines?
From yours and his Summary pages, they were 6 hours apart (Local time), but since they're equal now, one of you must have changed his page - and moved you 1/4 around the world in the process ;D
Offline guru
  • Robotics, CNC, Electronics, Programming
« Reply #14 on: March 12, 2010, 10:26:54 PM »
For soldering this sort of stuff one of those butane solder pens from Radio Shack work great. Regular soldering irons I find just cool down too fast to be useful. I used to solder brass together using the butane soldering irons, endless heat for gobs of solder.
« Reply #15 on: March 12, 2010, 11:07:23 PM »
Try a WTCP50 with a short wide tip, It will solder a car starter cable   ;D
« Reply #16 on: March 13, 2010, 09:57:17 AM »
Okay, I think I get what you're talking about! :)
Rock Robotics
Last post May 07, 2007, 06:43:47 AM
Last post January 17, 2008, 04:07:00 PM
by BANE
Last post January 24, 2008, 12:14:53 PM
by Del
Last post August 29, 2012, 07:50:12 AM
by ankitbansal
